Results 1 to 15 of 16
Thread: Hercus 260 as a first lathe?
8th Jan 2008, 09:37 PM #1New Member
- Jan 2008
- melbourne
- 4
I'm looking to buy my first lathe and have found a Hercus 260 for $1500.
From the ad: "3 & 4 jaw chucks, norton quick change gear box, metric lead screw, roller bearing head, good working order"
I've only seen a picture of it, and am going to have a look at it this weekend.
I'm a complete novice and have ordered some books to tell me what to do(!).
My main use is to generally have a play and to make the odd part etc. for my motorbikes.
I'm interested in any wisdom you might have:
- Is this a good machine to buy?
- Have you any advice as to how I might assess it when its in front of me?
- If its ugly, what would I have to replace (spindle bearings, rack etc.) to make it beautiful? Is it financially realistic to replace such parts if necessary? (For example I've think I've read somewhere about a Hercus 9" that needed new precision bearings that could cost $1000).
- What sort of accuracy would I expect from such a beast?
- I want to cut imperial threads. Do I need an imperial lead screw to do this, or is this where the magical 127 tooth cog comes in? I've ordered the book on screwcutting, so its not an explanation of screwcutting I'm after (yet!), just an evaluation of the difficulty (or ease) to set it up to cut imperial threads.
Any other thoughts etc. would be greatly appreciated.
Thanks,
Darren
8th Jan 2008, 11:19 PM #2Product designer retired
- Nov 2006
- Heidelberg, Victoria
- 79
- 2,074
Hi Darren,
Sounds like a very reasonable price, go for it. Hercus made quality lathes unlike some Chaiwonese lathes made today.
Don't concern yourself about the headstock bearings, since it's a 260, it won't be that old in terms of lathe age. The Timken taper roller bearings will last a life time, unless left to rust as mine have.
Accuracy is as fine as you will ever need.
Can't advise you on cutting imperial threads on a metric lathe, haven't explored that possibility yet.
Go and get it tomorrow, you will have a lot of fun.
For a bit more info, visit http://www.lathes.co.uk/hercus/index.html
Good luck,
PS, if you decide not to buy it, please let me know.
Ken
8th Jan 2008, 11:39 PM #3Diamond Member
- Sep 2006
- Australind , WA
- 58
- 1,277
I second that motion. That should be a great lathe for you to learn on and then to keep!
Make sure you get as many accessories form the seller as he is willing to give you in the deal. You never know what treasure he may throw in.
Hercus, Boxford, Myford and several others,are all clones of the 9" South Bend Lathe made in the US, so any manual relating to any of those will be useful to you and there are several you can download in pdf format.
We have 2 Hercus 260's at work and they survived the 25 years have been there no worries.
Sterob
9th Jan 2008, 06:47 AM #4
G Day Darren,
Let me add my voice to the weight of opinion on the Hercus 260.
These particular lathes have been a mainstay of turning practice in the high school system for 40 years or so. Most of them are still in use. That alone speaks volumes for a machine that survived the rigors of the High School system for that long.
If in good condition you are getting the lathe for a $1000 less than what a machinery reseller can ask for them. Our school bought a couple at $2500 each this year to add to the ones we have already.
There a ton of spare parts readily available.In fact easier in most cases to obtain than those of a cheap Hokinese lathe.
Example : the the cross slide dials were hard to read after years of work -new ones cost $65 each and turned up in a week or so.
$1500 is excellent value.
9th Jan 2008, 10:42 PM #5Senior Member
- Feb 2007
- brisbane
- 245
Threading imperial on a metric lead screw is the reverse of having an imp lead screw cutting metric.
So do a google and you will find heaps of info.
Essentially as long as you have the change gears applicable and the chart that shows what positions the gears go in to give "x" thread you are right.
All you do is engage the slowest speed, engage the half nuts, make a pass, quickly back out the cross slide as you stop the spindle, reverse the lathe and repeat until you reach thread depth.
As long as the half nuts remain engaged on the leadscrew you will be fine....so just make sure it comes with the change gears and you will be fine.Cheers
Craig
Brisbane
12th Jan 2008, 09:21 PM #6
Darren,
At $1500, and assuming it's not a dog, that's a great deal.
Like everyone else has already said, go for it!
you won't regret it.
ShaneA man who thinks that it can't be done shouldn't interrupt a man who's doing it........
16th Jan 2008, 12:02 AM #7New Member
- Jan 2008
- melbourne
- 4
I've done it
Well, today I rang up and said I'll do it.
I got the vendor to throw in 2 stud gears (25T & 50T) and a 48T screw gear. If I understand it correctly this should enable me to cut most of the imperial threads (from the 3mm pitch metric leadscrew - please correct me if I'm wrong!). Hopefully he'll come good with those. I also asked him to throw in a couple of tools so I can play with it when I get it home...
I spoke to the guys at TECO about inverters and they were most helpful. They said to bring the motor in, and we can then contemplate replacing it with a single phase motor, or use a FM50 inverter (I think that's the right model - the details are at the office). The inverter is roughly twice the price of a motor, but the speed control might be nice....
I also spoke to the tafe college where the lathe came from and the guy there said there was no problem with it, and they got rid of a couple of lathes to buy a new flash one.
So all things are pointing to happiness.......
16th Jan 2008, 06:04 PM #8
16th Jan 2008, 10:21 PM #9Senior Member
- Feb 2007
- brisbane
- 245
17th Jan 2008, 07:07 AM #10New Member
- Jan 2008
- melbourne
- 4
Mal,
I don't know what happened to the others. I'm buying it off a 2nd hand machine dealer down here. He's only got the 1 260, but there's also a 9" there too.
17th Jan 2008, 12:10 PM #11Product designer retired
- Nov 2006
- 79
- 2,074
Hi Darren,
Please let me know the name of the dealer, either in this forum, or via a PM.
I am still chasing a few bits and pieces for my 9" Hercus AR.
Ken
2nd Jan 2009, 12:07 AM #12
Hi,
The 260 is a great lathe I once owned both the 260 and the older 9" AL Hercus. The 260 is a bit heavier / stronger in constructiion. all the controls and techniques are the same. I might still have a set of imperial gears in the shed from the 260.If it goes against the grain, it's being rubbed the wrong way!
7th Jan 2009, 06:34 PM #13New Member
- Jan 2008
- melbourne
- 4
Speedy,
I'd certainly be interested in any gears and/or any other bits you may have for the lathe.
Haven't had much time on it of late (young child syndrome), but at least its there and waiting for me!
9th Jan 2009, 11:49 PM #14
I'll have a look to see what I have in the shed
10th Nov 2012, 08:27 PM #15New Member
- Sep 2012
- Warracknabeal, Victoria
- 1
Imperial threading using an ATM
Good to some one else is bamboosaled with thread cutting. Can any one inform me as to what gears are required for imperial threading with my metric 260? and a source of such gears.
also wouldl gears from hercus 9 be suitable? thanks fellows.
cheers
kev.
Reversing switch Hercus lathe?
By neksmerj in forum METALWORK GENERALReplies: 41Last Post: 31st Dec 2022, 11:21 PM -
Hercus lathe, logo sticker
By neksmerj in forum METALWORK GENERALReplies: 24Last Post: 5th Sep 2010, 12:03 AM -
Hercus lathe motor details
By neksmerj in forum METALWORK GENERALReplies: 5Last Post: 25th May 2007, 04:53 PM -
Hercus Lathe
By Penpal in forum METALWORK GENERALReplies: 16Last Post: 14th Feb 2007, 02:18 AM -
9 inch Hercus Lathe
By brianc in forum METALWORK GENERALReplies: 4Last Post: 18th Oct 2006, 04:34 PM
