Results 1 to 15 of 30
Thread: Will solder hold?
17th Dec 2007, 05:00 PM #1
Will solder hold?
Hi Guys.
I have just made this gate from steel, I used a soldering iron to stick all the metal together, it was a 200 amp jobbie which by my reckoning a is pretty powerful gizmo.
It should hold together shouldnt it?
17th Dec 2007, 05:06 PM #2Retired
- May 1999
- Tooradin,Victoria,Australia
- 73
- 5,457
Good iron to leave burn marks like that.
17th Dec 2007, 05:37 PM #3
Nice one Al, I take it you bent all the scrolls with your new bender from Metalcraft?
Don't think that one will be coming apart in a hurryCheers
DJ
ADMIN
17th Dec 2007, 05:45 PM #4
I used the muscles in my arm as the form and held the rod in my teeth.
Gees you blokes are too good, I cant put nuffin past youse.
Here it is before hangin.
17th Dec 2007, 06:55 PM #5Member: Blue and white apron brigade
17th Dec 2007, 07:03 PM #6
That gate looks like asian sign language to me.
What does it say brickie?woody U.K.
"Common looking people are the best in the world: that is the reason the Lord makes so many of them." ~ Abraham Lincoln
17th Dec 2007, 07:10 PM #7.
- Jul 2005
- Victoria
- 17
A lot of work in them, well done
Not my cuppa though, as they look a bit like a dogs breakfast, still good work
17th Dec 2007, 07:10 PM #8
17th Dec 2007, 07:14 PM #9
17th Dec 2007, 07:17 PM #10
No one else can read it.
Back in a mo, there is someone at the door..
17th Dec 2007, 08:07 PM #11
Hi
It needed to be powerful to heat up THAT size metal. However that does not mean that the joint is "stronger".
That's a LOT of work. I would have used THAT job to justify a welder to SWMBO
That solder WILL slowly deteriorate. It make take a few years but it will eventually break down. That's why the old soft soldered gutters began to leak and needed to be repaired/replaced. If you keep the gate painted (the joints specifically) with an oil based paint then it will last a bit longer.Kind Regards
Peter
17th Dec 2007, 08:21 PM #12
17th Dec 2007, 08:41 PM #13.
- Jul 2005
- Victoria
- 17
18th Dec 2007, 06:12 PM #14Intermediate Member
- Aug 2006
- 32
Unfortunatley with solder NO
Unfortunatley because of design (or may I humbly say, lack of it) unfortunatley looking at a failure.
Regards.
DenLast edited by cub3; 18th Dec 2007 at 06:13 PM. Reason: added with solder
18th Dec 2007, 06:54 PM #15.
- Jul 2005
- Victoria
- 17
Aluminum Solder
By Nurgle in forum METALWORK GENERALReplies: 7Last Post: 2nd Aug 2007, 12:46 PM -
Solder Flux?
By Walesey in forum METALWORK GENERALReplies: 5Last Post: 19th Jun 2007, 05:54 AM -
Silver Solder Pt 2 How to
By Grahame Collins in forum METALWORK GENERALReplies: 0Last Post: 11th Jan 2007, 10:51 AM
