Results 1 to 9 of 9
Thread: FS: Transtig 180
16th May 2007, 11:54 PM #1Novice
- Jan 2007
- Wollongong, NSW
- 16
FS: Transtig 180
Transtig 180. Purchased a few months but have since been given a newer Tig for nothing (lucky me ). Everything works, happy for you to take it for a test drive.
Come with
- Trolley
- New heavy duty earth lead and clamp.
- Comes with 3 phase plug but can easily be converted to single phase - just a simple change of wires on the inside
- New ceramic cup
- Comes with misc torch accessories
- Instruction manual provided
Going for $1800 in shops, im after $1400 but feel free to make a reasonable offer.
Located in Wollongong, NSW 1 hour drive south of Sydney.
PM or call 0403 279 000
Ariel
14th Jun 2007, 10:47 PM #2Novice
- Jan 2007
- Wollongong, NSW
- 16
want it gone, taking up space which i need for other machinery on the way...make an offer even if it is stupid
16th Jun 2007, 10:47 AM #3
Attention ! Those wanting to weld aluminium stainless steel
From time to time there are contributors asking what TIG machine to buy.
THIS ONE - Tig AC (aluminium),Tig DC (stainless steel and steel) Stick AC-most electrodes DC LH ,stainless, cast iron electrodes. Very versatile.
Its a fair dinkum working machine not a toy.
If you wish to weld aluminium, steel and have stick capability on AC and DC as well as well. The current models with these features will cost you around $5000.
They are are well made and long lived machine.
There are heaps of them still in workshops around Australia.
Check on parts availability and I am sure you will find no problems.
A good way of checking them out is to pick up the yellow pages and ring a shop that repairs welders.They will tell what is good and what is bad.
I have no connection with the seller, but thought I need to make the point about quality machines, again.
I have no idea about current $ values on them so please don't ask!
16th Jun 2007, 02:21 PM #4Novice
- Jan 2007
- Wollongong, NSW
- 16
Thanks Grahame, I done exactly that. Rang about 20 different welding supply shops in Sydney and Wollongong and finally decided to go ahead with the purchase of this one.
Research is your friend, espcially when you want to spend serious $$$
Ariel
24th Jun 2007, 09:20 AM #5Novice
- Jan 2007
- Wollongong, NSW
- 16
any takers, need it gone...taking up much needed space and i have no use for it
there is absolutely nothing wrong with it. happy to give anyone a test drive
24th Jun 2007, 11:44 AM #6Golden Member
- Jun 2005
- Helensburgh
- 618
Gee I wish I needed a TIG, what a bargain. I will give it a good home in case I need to use it and it will only be 30 minutes away if you need it again
CHRIS
25th Jun 2007, 08:08 PM #7Novice
- Jan 2007
- Wollongong, NSW
- 16
at the rate im going i might just give it away
25th Jun 2007, 09:04 PM #8Senior Member
- 316
25th Jun 2007, 10:10 PM #9Golden Member
- Jun 2005
- Helensburgh
- 618
Bad luck, I live just up the road. I'll be right down to pick it up Ariel.
CHRIS
Transtig 180 ac/dc welder
By kr_cf in forum WELDINGReplies: 47Last Post: 25th Oct 2012, 09:40 PM
