Results 1 to 3 of 3
Thread: Hafco Taps & Dies
25th Apr 2007, 07:05 PM #1Novice
- Nov 2006
- King Island, Australia
- 16
Hafco Taps & Dies
Has any body had experience with the Taps & Dies (UN & Metric) sold by Hafco. They have two types for the Metric (Alloy and HSS) and only alloy for the UNC/F.
Donald
25th Apr 2007, 10:00 PM #2Golden Member
- May 2003
- 526
Get HSS as the alloy ones break easy - usually in a critical part or when you drop them on the floor.
I have the metric set of HSS from H&F and they are good. I don't use UN so can't comment.Cheers,
Rod
26th Apr 2007, 12:29 AM #3Member: Blue and white apron brigade
It would be useful if you could buy a mixed set. I don't recall ever breaking a carbon steel tap bigger than about 3/8". I usually break those 1/8" cheap carbon steel taps, Maybe I'll get myself some individual sets of 1/8" in HSS. The other day I dropped a Carbon Steel M6 die onto my bench from about 20cm and a bit chipped off it, still cuts an OK thread.
Hafco lathes
By benboy in forum METALWORK GENERALReplies: 7Last Post: 24th Sep 2006, 05:24 PM
