Results 1 to 11 of 11
    Jun 2006
    Bulleen, Melbs
    42
    21
    Default Hydrochloric acid for Damascus?
    I need to do a light surface etch on Damascus steel. Does anyone know if i can buy small quantities of Hydrochloric acid in Melbourne.
    Or...
    Even better, is there someone in melbourne who does this who could help me out.
    Ta.
    Ben
    Art has now be-come
    Sim-ply an ex-cuse to sit
    In the Sun . What Fun!
    BC-haiku
    Aug 2003
    1,175
    Any hardware shop should sell it, its used for cleaning down brickwork.
    Al
    Oct 2003
    Sydney,Australia
    174
    Depending on just what sort of 'damascus' you are etching, good results on wootz can be had with ferric sulfate, while nickle/iron pamour (kris iron) traditionally was etched with lemon juice and arsenic (yummy!) - apparently you don't absorb enough thru' the skin to kill you, you just look very well preserved in you old age (check Herodotus on that).
    Hydrochloric is OK for DIY iron/steel mechanical 'damascus' but it will cause ongoing corrosion if there are any cold shuts or other defects in the steel unless you neutralise it.
    May 2005
    Turramurra, NSW
    66
    If you still want Hydrocloric acid, just bludge some off any of your mates with a pool.
    They'll have gallons.
    I use Sulphuric from old batteries.
    Bodgy
    "Is it not enough simply to be able to appreciate the beauty of the garden without it being necessary to believe that there are faeries at the bottom of it? " Douglas Adams
    Jun 2006
    Bulleen, Melbs
    42
    21
    Thanks guys.
    From what i have read, i should use a mix of sulphuric (which i can get from work) and Hydrocloric.
    Its a bar of 1095 mild steel btw
    Ta.
    Art has now be-come
    BC-haiku
    Jan 2005
    Geelong, Victoria
    23
    i think the standard used acid is feric chloride. usually in a mix with a little water i think 1 part feric to 2 water sounds about right.
    you can get it from dick smith or tandy, they use it to etch printed circuit boards, its not that expencive either.
    if you wnt an exact method check out KNifenetwork.com do a search and youll find oodles of info.
    brett
    7,182
    Quote Originally Posted by holmsy2000 View Post
    brett
    Yep, I vote the ferric chloride, safer than HCl and more controlable. You can sit and watch the HCl for some time and not much seems to be happening so you go go away and leave it and when you come back you can end up with holes everywhere or even no metal and a pile of sludge in your tank.
    Oct 2005
    CANADA
    4
    Default etch
    The damascus has to be sanded up to 600 grit min or the etch will not come out with much contrast. Ferric can be had as electronics board etch.
    Rinse with a base like backing soda when finished your etch to stop the acid.
    Cheers Ron
    Jul 2003
    Near Bodgy, AlexS, Wongo & CraigB
    18
    124
    did you maske the damascusing yourself ? please post a pic.
    Zed
    Jun 2006
    Bulleen, Melbs
    42
    21
    Sorry its been awhile and for the lack of photos. I'll post them when the blade is finished, which it nearly is.
    I tried an etch using Ferric chloride on a scrap and that seems to work.
    Ben
    Art has now be-come
    BC-haiku
    Jun 2006
    Bulleen, Melbs
    42
    21
    Quote Originally Posted by Zed View Post
    And no. I bought the bar from an Ebay shop.
    Art has now be-come
    BC-haiku
