Results 1 to 10 of 10
24th Aug 2006, 10:58 PM #1Intermediate Member
- Jan 2006
- Malvern East
- 36
How should I treat exposed steel?
I am curently rebuilding a trailer and it has a bit of surface rust on it. I have just finished removing the metal floor from it and as a result grinded nearly all cross members down to the steel.
What should I use to prepare the steel ready for paint?
For the moment I have just hit it with some gloss black paint I had lying around.
Brenton
24th Aug 2006, 11:00 PM #2
Not that I know much about metalworking but I would be inclined to use some sort of rust inhibiter...
Along the lines of galmet. It can be sprayed or brushed on and works well.
Pete
24th Aug 2006, 11:06 PM #3
Provided it's bright steel and no rust left, I really like the bitumised paints. They are also soft, so that any metal you overlay has a bit of a cushion. Unfortunately it takes 2 weeks to fully dry and your chioce of next coats is limited.
Alternately Cold Gal, always assuming there's no rustBodgy
"Is it not enough simply to be able to appreciate the beauty of the garden without it being necessary to believe that there are faeries at the bottom of it? " Douglas Adams
24th Aug 2006, 11:11 PM #4
Use something like "KillRust Cold Galvit".
The paint contains stuff that inhibits the further development of rust and the galvanic components protect from future rust. Make sure that you give it a really nice thick coat on all components (including mating surfaces) before you put the floor in. Then slop some more on the weld areas after the floor has gone back in.Have a nice day - Cheers
24th Aug 2006, 11:24 PM #5Member: Blue and white apron brigade
- 7,182
Originally Posted by BrentonSpear
A cheap rust inhibitor is dilute phosphoric acid, it turns red rust into iron phosphate (blue) and when it dries you can paint right over that. I would recommend stripping off the gloss paint and using a proprietary rust inhibitor and then some decent paint. That galvit stuff that wood butcher describes is also top stuff.
24th Aug 2006, 11:46 PM #6Senior Member
- 316
Hi,
Here is the info pertaining to the "GALVIT" stuff.
http://www.wattyl.com.au/Specifiers/...ils.htm?Id=387
& here is the site for the "GALMET" stuff. There is also a FAQ section.
http://www.galmet.com.au/driver.asp?page=main/home
David
25th Aug 2006, 12:16 AM #7
Once you've finished treating all the steel, consider putting in a ply floor instead of steel. Makes for a quieter trailer and guaranteed not to rust! . I've had a sheet of 15mm exterior hardwood ply in the trailer that I built more than 6 years ago and it's still sound. It should see out ten years and only gets a coat or two of decking oil every year or so). Glue it in place with a cartridge of sikaflex and a handful of rivets or teks. It will be a lot easier to replace than a steel floor too.
Mick"If you need a machine today and don't buy it,
tomorrow you will have paid for it and not have it."
- Henry Ford 1938
25th Aug 2006, 09:18 AM #8Registered
- Aug 2003
- 1,175
Take it to a movie, have dinner together, but it flowers.
Al
25th Aug 2006, 09:27 AM #9
How long does it flower for?
27th Aug 2006, 02:09 PM #10Originally Posted by BobL
Welding question ? ... Is this dangerous ?
By JDarvall in forum WELDINGReplies: 36Last Post: 9th Mar 2006, 12:29 PM -
Corrugated steel strips: Where to buy? How to make?
By Peter Dow in forum METALWORK GENERALReplies: 6Last Post: 20th Jun 2005, 10:28 PM
