Results 1 to 12 of 12
    Sep 2006
    Australind , WA
    58
    1,277
    Default Digital Height Gauges
    I'm thinking of buying a digital height gauge. Don't need a big one...about 150mm should do.
    Don't want to spend a fortune as I don't know how often I will get to use it, but I want one that works well......
    Saw the cheapies on Ebay ($28! )but I am wary. Anybody bought one of these?
    Happy with it?
    Any better options?
    Happy to spend a $100 or so on one. Not sure a S/H one would be a good buy, unless it was looked after.
    Don't need super accuracy....) 0.25mm will do.
    Has to be digital as my eyes are lazy.....lol
    Edit: I see Timbercon have one. That may do the trick.
    Apr 2012
    Healesville
    2,129
    Hi Steve, I have one of these https://www.ausee.com.au/shop/item.aspx?itemid=3683
    It was cheap and seems to work for what wanted it to do, I mostly use it for setting tool heights.
    cheers, shed
    7,183
    The $28 ones have plastic bases - I reckon the ones with a cast iron base are much more stable.
    The other thing really worth having a fine height adjustment thumbscrew.
    Something else to watch out for is the hardened scribe - some are just hardened steel but the better ones have carbide tip.
    I bought mine (an 8") from https://www.ausee.com.au/shop/category.aspx?catid=7171
    The one small thing that peeved me off about the Unit I bought was the battery was not held in firmly enough so that every now and then (ie usually just when I wanted to make a critical measurement) the battery lost contact.
    I contacted Aussee about it and they were prepared to replace it but I fixed it by slipping a double up piece of plain paper in behind the battery.
    But maybe if you just want 0.25mm accuracy the $28 will do the job.
    Sep 2006
    Australind , WA
    58
    1,277
    Thanks guys.
    Will definately go with the cast base and hardened tip.
    Sep 2006
    Australind , WA
    58
    1,277
    This may even do the trick for me....
    30 pound from UK.
    May 2019
    Tucson, Arizona, USA
    46
    Quote Originally Posted by Sterob View Post
    Happy with it?
    Any better options?
    Hi Steve,
    This is one that I think would work well for you. I do not own this particular gauge, but I do have some of their digital calipers and digital scales that are very high quality and work well. In fact, the iGaging 6" digital calipers are on par with the Mitutoyo at about 1/4 of the price.
    David
    Note: Here is the link and information about this height gauge. It seems that my originals were deleted from this post for some reason (not by me).
    https://www.amazon.com/iGaging-Digital-Electronic-Height-Magnetic/dp/B0026MTCG8
    Last edited by adbuch; 19th Jun 2019 at 01:43 PM. Reason: Replaced deleted image and link
    Sep 2006
    Australind , WA
    58
    1,277
    Thanks David. I will check it out.
    6,439
    Hi Steve,
    For what its worth, I built my own using a cheap digital calliper. It does the job and whilst it gets little use its great for setting and scribing a line at a specific hight on the work.
    This is the gauge that I made. The hight adjustment is a length of M6 stud bar driving a moulded on acetal nut turned down to be a tight press fit in the cross bar.
    The base is a cast iron disc, faced and trued on both sides. A hole was drilled to take a length of polished bar from a defunct printer. One of the phosphor bronze bushes from the printer was used as a guide bush. A slot was cut in the opposite side to accommodate the calliper frame and secured by a couple of grub screws.
    The other half of the inside jaws was cut off and used to make the measuring/marking tip. The calibration was checked using a known length of steel rod.
    In use the knurled brass knob at the bottom was used to set the required hight. At 1 mm per turn it is easy to set to a hundredth of a mm.
    Sep 2006
    Australind , WA
    58
    1,277
    Nice work Baron!
    I wish I had the time to make one.
    I need it for a job so if I make one that slow the first job down. A Makers Conundrum....
    May 2019
    46
    That's a great job Baron! Great ingenuity.
    David
    jatt's Avatar
    jatt is offline Always within 10 paces from nearest stubby holder
    Bendigo
    51
    760
    Does the job for sure. Do like the use of salvaged printer bar. Already polished up ready for use!!
    Frisky wife, happy life. ​Then I woke up. Oh well it was fun while it lasted.
    From an early age my father taught me to wear welding gloves . "Its not to protect your hands son, its to put out the fire when u set yourself alight".
    Jun 2007
    Ipswich QLD
    68
    1,996
    Just read a post elsewhere fellow made one using a digital vernier
  1. BSP Cap Screw Gauges x 2 (Go/No go gauges - Snap Gauges) FREE
    By John T K in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 1st Oct 2017, 01:20 PM
  2. Replies: 3
    Last Post: 29th Oct 2013, 11:03 AM
  3. Digital height gauge instructions
    Last Post: 3rd Oct 2012, 07:39 AM
  4. Home Made Digital Height Gauge
    Last Post: 10th Jul 2007, 12:25 AM
