Results 1 to 13 of 13
Thread: Paint stripper
17th Jun 2019, 01:36 AM #1Senior Member
- May 2019
- Picnic Point, Sydney
- 77
- 312
Paint stripper
It wasn't that long ago that paint stripper did just that ... strip paint. Not any more. Apparently methylene chloride was the ingredient that did the stripping but legislation has had it banned so now we have products that are useless in the real world of stripping paint.
Does anyone know of a paint stripper that really does what the label says or maybe a recipe so I could make something up at home?
17th Jun 2019, 01:59 AM #2China
- Dec 2005
- South Australia
- 1,656
17th Jun 2019, 07:28 AM #3Senior Member
- May 2019
- 77
- 312
That MIGHT work on a brushing enamel but on a single coat of lacquer it's about as good as using water.
I bought that stuff from Bunnings because 10 years ago I used it on the same lacquer and it was perfect but unfortunately today's environmentally safe Polystrippa is useless.
17th Jun 2019, 08:12 AM #4Philomath in training
- 6,541
I've had great success with a 50:50 mix of meths and turps. Don't know whether it will work on lacquer, but it's good enough to resuscitate dried paint brushes, so does have some umph.
17th Jun 2019, 09:00 AM #5
Go to a auto spray supplier. Super cheap have one that I've been using and am happy with.
It's around $60 for 4ltr, but if you want high strength top shelf stuff, talk to you high quality paint/panel supplier. After all there stripping 2 pac etc.Using Tapatalk
17th Jun 2019, 09:43 AM #6Most Valued Member
According to the Bunnings website my local store has 1L tins of original Polystrippa in stock. Says it has methylene chloride in it.
17th Jun 2019, 09:45 AM #7Member: Blue and white apron brigade
- 7,183
Polystrippa still contains 90% methylene chloride (see here https://msds.orica.com/pdf/shess-en-...0703277501.pdf) so it has not been banned.
According to the MSDSNo long terms exposure information is available for methylene chloride. Available evidence from animal studies indicate that repeated or prolonged exposure to this material could result in effects on the liver and kidneys. Some animal test data suggests a carcinogenic potential for this material. These particular data sets are not considered relevant to normal industrial use but do emphasise the need for care in handling.
17th Jun 2019, 09:50 AM #8Most Valued Member
17th Jun 2019, 10:31 AM #9
Sort of!
No ban here in Australia but overseas, there is.
I would expect soon will be it on the legislators to do list.
If your selected paint stripper is made offshore its a fair conclusion that there's some new 'old stock" held by retailers but will soon be replaced by the alternate formula.
Read your labels before purchase.
17th Jun 2019, 10:48 AM #10Most Valued Member
In that case I'm going to grab a couple of cans next time in Bunnings.
17th Jun 2019, 11:35 AM #11Senior Member
- May 2019
- 77
- 312
There has definitely been a change in the formula because the lacquer used to lift as you painted the stripper on and the brush would remove it as you worked. I don't see any paint crazing now and scraping with a piece of wood or plastic does nothing.
17th Jun 2019, 11:39 AM #12Diamond Member
- Feb 2013
- Laidley, SE Qld
- 1,038
I've DIYed paint stripper using sodium hydroxide NaOH (caustic soda, lye) as the active ingredient. It needs to be in jelly form to stop it running off the surface, the goop can be flour, corn flour, wall paper glue, whatever is to hand. It doesn't soften all paints, methylene chloride is the king there.
Pure NaOH can be bought cheaply in 10kg pails from suppliers to commercial cleaners. Be wary of the 500gm NaOH drain cleaners from the hardware, they often contain 50% table salt, read the labels.
Apply the usual safety rules.
17th Jun 2019, 11:42 AM #13Most Valued Member
There are TWO formulas. The original, with methylene chloride, which you can still buy and the new formula which doesn't contain methylene chloride. You said in a previous post you have the new formula.
New formula:
Polystrippa Paint Stripper Advanced | PolyChris
More Green Paint
By Anorak Bob in forum THE HERCUS AREAReplies: 9Last Post: 16th Dec 2013, 10:02 PM -
What colour paint?
By neksmerj in forum THE HERCUS AREAReplies: 0Last Post: 28th Nov 2012, 04:58 PM -
where to get ute liner paint
By Gaza in forum TRAILERS & OTHER FABRICATED STUFFReplies: 13Last Post: 16th Mar 2012, 09:28 PM -
Pulleys... Paint or no paint?
By Com_VC in forum THE HERCUS AREAReplies: 5Last Post: 3rd Apr 2011, 08:42 PM -
How much for a good stripper
By neksmerj in forum THE HERCUS AREAReplies: 13Last Post: 30th Dec 2008, 01:11 PM
