Results 1 to 5 of 5
Thread: Forklift woes
16th Jun 2019, 11:18 AM #1
Forklift woes
Sometime ago I had a post about replacing the petrol engine in a forklift with a diesel.
Well still trying to locate a working replacement diesel that does not have any electronics in the fuel system.
I located one of the major problems with the petrol engines ignition system , one night I had to start it and had the engine cover up so that I could connect the battery leads.
I was standing on the same side as the distributor and coil , noticed a short blue spark occasionally when cranking , back whenever a "mechanic " had replaced the coil , this person had overtightened the clamp on the coil that much that the outer case had deformed to the extent of cracking and over a period of time insulation had broken down .
Just another case of heavy handed idiots at work.
Replaced the coil and now it will start easier but its still getting a transplant as soon as I locate a decent perkins or kuboto diesel.
Have found a few which the owners wanted almost new price for a pile of scrap.
Will keep looking , as I want to keep this machine as it can be operated without height issues in my building and yard.
16th Jun 2019, 12:04 PM #2Most Valued Member
- Australia east coast
- 2,713
So buy a new engine. Boats use small kubotas so they have to be available.
PDW
16th Jun 2019, 03:26 PM #3
PDW, I have been informed of a newish Kubota , I am contacting the seller tomorrow.
I will try to make the swap as modular as possible so that it is easier maintenance when the time comes.
16th Jun 2019, 03:55 PM #4Diamond Member
- Aug 2006
- 1,105
Last time you said you bought a Toyota Diesel engine, how come that didn't end up going in?
16th Jun 2019, 06:28 PM #5
The head was cracked and coolant had leaked into 2 cylinders , more costly to repair than I wanted to spend .
Forklift engine change
By Mike4 in forum GENERAL DISCUSSION / OFF TOPICReplies: 7Last Post: 22nd Feb 2019, 12:03 PM -
Forklift tynes
By glivo in forum EBAY, GUMTREE, and other off forum sales sitesReplies: 1Last Post: 13th Jul 2018, 09:21 PM -
Toyota forklift handbrake
By caskwarrior in forum METALWORK GENERALReplies: 11Last Post: 7th May 2017, 01:15 AM -
Hyster forklift repairs
By snapatap in forum METALWORK GENERALReplies: 7Last Post: 27th Oct 2015, 09:06 AM -
8T forklift or thereabouts
By dave4 in forum METALWORK GENERALReplies: 2Last Post: 6th Jul 2014, 11:20 AM
