Results 16 to 23 of 23
Thread: Mist coolant and breathing
14th Jun 2019, 01:33 PM #16Member: Blue and white apron brigade
There are many things in metal shops that are unhealthy but untangling these from domestic and other factors have only become possible in recent times. Plain old dust was recently raised from the 8th leading cause of death in the world to the 5th leading cause of death. Most people think of the dangers of dust in terms of "lungs" but it is now established that dust contributes significantly to coronary diseases, strokes. and other diseases.
14th Jun 2019, 03:47 PM #17Gear expert in training
- 34
- 1,079
Air quality is one of the main reasons I had to leave the timber industry, that's why I wanted to find out how controllable the mist systems are. I had a couple of days on the cylindrical grinder last year and was glad I kept my powered mask; there is a fume hood, but it doesn't get everything and in a small closed room (gotta be climate controlled) the smell was really noticeable.
I've had a generous offer of a loan of a Minicool, so I'll be able to see how it performs before making a decision.
15th Jun 2019, 02:58 AM #18Senior Member
- Aug 2007
- 292
I inspected parts in an aerospace machining plant for 27 years. Even though I never actually worked at the machines I was close enough to be breathing the mist from the coolant. Some operations were with misters and much was flood coolant. They blew the parts and tables off with shop air with up to 1/2" nozzles and much of that was atomized. The big mill was 190' long and 11' wide with 4 gantries with 2 or 3 heads each to give you an idea of how much was thrown into the air. The coolant turned the metal foil backed insulation on the walls brown in a few years and everything was coated with a sticky residue. There was an operator (about 58 years old and worked there 20+ years) that went on compensation to eventually get pensioned off because of lung damage. I feel I have some respiratory damage from the coolant too but not enough that it will kill me. Just help it along a little. I won't use a mister in my home shop but would use a cold jet of shop air for the appropriate work. I use a respirator when squirting coolant/lubricant when turning or milling. Don't let anyone tell you that a water based coolant can't hurt you. Enclosed machines with mist buster/condensers if properly designed and maintained can help but you still need good ventilation too.
Pete
15th Jun 2019, 10:26 AM #19Most Valued Member
15th Jun 2019, 10:51 AM #20Member: Blue and white apron brigade
Rust?
A $20 bathroom fan and a length of aluminised coated plastic ducting like this from bunnings should go a long way to solving this problem.
15th Jun 2019, 11:23 AM #21Most Valued Member
15th Jun 2019, 11:25 AM #22Most Valued Member
Actually I have a surplus inline ducted fan that I might press into action as Bob suggests. I'm actually more concerned about the acrid smoke that I get when making heavy cuts in steel with cutting oil.
15th Jun 2019, 11:27 AM #23Member: Blue and white apron brigade
Mist Coolant systems
By BobL in forum METALWORK GENERALReplies: 37Last Post: 14th Aug 2019, 10:20 PM -
Mist coolant spray.
By adyadad in forum METALWORK GENERALReplies: 6Last Post: 19th Sep 2018, 07:39 PM -
Mist Coolant
By Auskart in forum METALWORK GENERALReplies: 3Last Post: 25th Aug 2018, 02:58 AM -
Surface grinder kicking up mist/fog
By variant22 in forum METALWORK GENERALReplies: 18Last Post: 11th Jun 2015, 10:12 PM -
Double banger - Duragal removal and breathing mask for welding
By twebb01 in forum WELDINGReplies: 5Last Post: 21st May 2015, 09:35 PM
