Results 31 to 36 of 36
14th Jun 2019, 08:37 AM #31Member: Blue and white apron brigade
If you would like to have a few imperials on hand consider getting MT collets instead of ERs. When I got my mill I already had ER32 metrics for my lathe so Anorak Bob gave me a few MT collets. 1/4, 3/8, 1/2" plus 6 and 12 mm. These are really handy because they are shorter and leave a bit more WWR (wiggle work room), especially on small mills and lathes
14th Jun 2019, 09:58 AM #32Most Valued Member
Lucky you. Is this what you are talking about? https://www.amazon.com/gp/product/B0...CBPE368U&psc=1
You can get them locally in MT2 and MT3. https://www.ausee.com.au/shop/category.aspx?catid=13Chris
14th Jun 2019, 10:17 AM #33Member: Blue and white apron brigade
Yes but they are of course MT4.
This smaller MNT3 subset are good value
https://www.amazon.com/dp/B01BH5Q7GM/ref=dp_cerb_1
This 11 piece set of imperials from CTC look like good value - shame about the freight costs.
MORSE TAPER #3 IMPERIAL COLLET SET (11 PCS) #F78 | CTC Tools
14th Jun 2019, 10:23 AM #34Banned
- Jan 2019
- 78
I bought an ER25 set which, I think, top out at 16mm. My lathe has a 25mm bore, a MT2 tailstock taper and 280 swing. I went for the ER25 because I use drills in them rather than work. It takes a fair amount of tightening to do the collet chuck up, so much so I added to the length of the chuck spanner. My lathe's drill chuck takes up to 16mm after that it's step down drills, hence the ER25 collets. Mine were sourced on ebay, the cheapest I could find. Excellent quality and I never had any problem with burrs.
14th Jun 2019, 10:45 AM #35Most Valued Member
A ball bearing nut might help with that if you don't already have one. It shouldn't be difficult to tighten them.
https://www.ausee.com.au/shop/item.aspx?itemid=1304Chris
14th Jun 2019, 04:02 PM #36Gear expert in training
- 34
- 1,079
+1 for ball bearing nuts.
If you want to stick with plain nuts, a drop of air tool or light machine oil on the tapered surface that presses against the collet (as well as a drop or 2 on the thread) can help keep things rotating more freely.
Milling machine types
By phaser in forum METALWORK GENERALReplies: 11Last Post: 6th Oct 2018, 10:19 AM -
Capacitor types
By kenny_10 in forum ELECTRICALSReplies: 2Last Post: 29th Jun 2018, 06:06 PM -
plus or minus on recommended speeds
By steamingbill in forum METALWORK GENERALReplies: 9Last Post: 26th Dec 2013, 09:48 PM -
Please help me...types of drawbar
By VXEXEC350 in forum TRAILERS & OTHER FABRICATED STUFFReplies: 2Last Post: 28th Apr 2009, 12:17 AM -
Various types of GMAW machines
By Grahame Collins in forum WELDINGReplies: 0Last Post: 24th Dec 2005, 10:22 PM
