Results 1 to 8 of 8
Thread: Belt grinder wheel bore size
7th Jun 2019, 12:40 PM #1New Member
- Jun 2019
- 4
Hi all. I'm struggling to find a supplier that makes or custom machines a 5" drive wheel to suit my drive shaft of 28mm. Anyone got any suppliers to suggest? I'm in Oz but can order internationally.
7th Jun 2019, 01:58 PM #2Intermediate Member
- May 2019
- Tucson, Arizona, USA
- 46
Hi Tim,
Please provide more details along with either a photo or drawing/sketch with dimensions and perhaps I can help you out.
Thanks,
David
Desert Hybrids Precision
7th Jun 2019, 11:59 PM #3Most Valued Member
- 5,945
As David mentioned, more details please. Are you after a 5" pulley with a 28mm bore??
What size belt will be fitted to it? Your request is a bit like saying "How long a piece of string will I need to go around this??"
Welcome to a TOP FORUM by the way.
9th Jun 2019, 01:30 PM #4
It might be a bit expensive to post from Arizona to South Australia but thanks for offering to help. It might pay to give these guys a call
https://www.artisansupplies.com.au/p...c=22783a5940ef
9th Jun 2019, 01:36 PM #5Intermediate Member
- May 2019
- 46
Tim said he has the capability to order internationally. He is asking for a source for a modified or custom machined part. So I can't see where the postage from US to Australia is really a problem.
If we knew the width of the wheel, along with some other details - there may be a source that we can locate to order it. Shipping from US to Australia or New Zealand is around $33 via USPS Priority Mail International Small Flat Rate Box. Perhaps we can locate one closer - But - we need more details to help Tim out.
David
9th Jun 2019, 04:10 PM #6Most Valued Member
- Healesville
- 2,129
If you cant bore out a pulley yourself then do a search for "power transmission supplies" in your area.
A power transmission supply business will supply you with a 5" pulley and they will bore the shaft hole to the dimension that you require....... and they will also put a keyway in it if you want.....
cheers, shed
duh..... drive wheel !!!!! same, take it to a power transmission supply business
9th Jun 2019, 05:43 PM #7Intermediate Member
- May 2019
- 46
Here is a 5" drive wheel with 24mm bore. Surely one of your buddies can bore this out to 28mm for you. Price is $59.99.
https://www.knifegrinderparts.com/products/belt-grinder-knife-grinder-5-drive-wheel-crowned-24mm-bore-6061-aluminum
9th Jun 2019, 11:20 PM #8Intermediate Member
- May 2019
- 46
The OP is probably not going to respond to his original post. So I think this post is dead. Thanks to all who responded.
David
Twin belt belt grinder.
By onanonanon in forum METALWORK GENERALReplies: 6Last Post: 18th May 2018, 03:52 PM -
Pulley and Belt size speed ratio Calculator
By KBs PensNmore in forum CONVERSIONS & CALCULATIONSReplies: 0Last Post: 4th Dec 2017, 08:50 PM -
correct vee belt size for a mill drill
By welder in forum METALWORK GENERALReplies: 5Last Post: 6th Jul 2011, 02:28 PM -
grinder wheel formulation
By soundman in forum METALWORK GENERALReplies: 2Last Post: 16th Jun 2005, 01:10 AM
