Results 1 to 14 of 14
Thread: Workshop layout.
23rd May 2019, 06:02 PM #1
Workshop layout.
I'm in the process of re-configuring my shed layout. Current machines are Hafco AL320 Lathe, Toolex RF31 Drill/Mill, small bench drill press and 2 bench grinders. Hoping I can fit in a small combination Bandsaw some time in the future. Without going into actual specifics of area available etc ,I'm be interested in hearing the peoples thoughts regards minimum work areas etc.
Hafco AL320G Lathe
Toolex RF31 Mill/Drill
Saber Bandsaw
23rd May 2019, 08:11 PM #2Member: Blue and white apron brigade
- 7,183
This is a bit of a, "how long is a piece of string?", type question. If you only work on small stuff you can have your machines very close together. If you work on big stuff then either you have to allow more space around machines or be able to easily move at least some of your machinery around.
My MW BS is shoe horned between my grinder stand and my DP. It might not look like it but the grinders have to be aligned a certain way to allow the BS arm to fully swing up out of the way. However by pulling the BS (on wheels) out about 100 mm there is enough clearance so that I can still cut up to 4m long stock with it in that location.
To tackle longer stock I have to wheel it into the short alley way that leads out the front door so that I cut longer stock up with the stock hanging out the door.
Same applies to my WW BS and planer thicknesser
Your bench, grinders and even the drill press could be put on wheels - the lathe and drill mill maybe not.
23rd May 2019, 08:39 PM #3
thanks BobL, its all a bit like big jigsaw puzzle, but I'll no doubt find the right combination sooner or later. I have about 7 square metres to play with, but given the effort required in moving and relocating the big bits of machinery, Id prefer to only have to do it once. I just need to guesstimate minimum clearances required to be able to work at each workstation.
Hafco AL320G Lathe
Saber Bandsaw
23rd May 2019, 08:39 PM #4
What ever space you do have,it will never be enough.
I have as many machines as practical mounted on castors.Whenever I need space I can wheel them away from the others that are stored all grouped together.
They are:
Drill press
Linisher
Horizontal band saw
Scroll saw
Permanently inverted Jigsaw-Worx brand machine from Masters.
20 ton Hydraulic press.
2.4m x 1.200m bench.
When I have a large messy job the machine to be used is wheeled to an outside covered area that can be later swept and hosed down afterwards.
23rd May 2019, 08:49 PM #5Member: Blue and white apron brigade
- 7,183
Well with that much space you will only ever be able to work on small stuff. I do know someone with a 6m^2 workshop and in that he has a lathe/mill/DP/grinder/linisher/bench and they are all basically hard up against each other with just enough room for his mill table to reach full extension and he gets to stand in the same spot in the middle. He works on small steam engines.
23rd May 2019, 08:54 PM #6Banned
- Jan 2019
- 78
I only have a small shed, 5m x 5m, so space is at a premium. I've graced several times trying to squeeze tools and machinery in. I'm pretty well sorted now with lathe, pedestal drill, bench drill, blasting cabinet, compressor, wood table saw, bar bender, two belt grinders, linisher, bandsaw, wood chop saw, metal table saw, two bench grinders. All the machinery is mounted on stands around the perphery of the shed, the 2' x 6' welding table is mounted in the middle. All my handtools are hung overhead. For storage I have two 3' long cabinets, a 5' long bench with compressor underneath, 2' x 6' welding table with two vices. eight 2' small drawer units, metal rack, mezzanine shelf for wood and a full sweet of cordless and corded tools. Lots in there, but keeping it tidy helps and is essential.
23rd May 2019, 09:20 PM #7Philomath in training
- 6,541
I'm like Grahame, in that I have lots of stuff on wheels, although only the small stuff. This is in a 6m by 6m garage that also has to house a car.
I'd start with some stands and ropes or boards. Place them around your machines and see how much room you do need. It will depend on your mobility as well as what you are doing. Once you know the envelopes you can play with bits of paper on a floor plan. Lots easier to move.
If you have access to old MEW's there was a short article about workshop layout in March 2008
23rd May 2019, 09:57 PM #8
thanks Micheal, great minds, I've just finished drawing a plan of my available space , next will be some cutouts of my machines.
Hafco AL320G Lathe
Saber Bandsaw
24th May 2019, 06:11 PM #9
further to my post above, can someone tell me the approximate footprint of a small metal combination Bandsaw, similar in size to the Hafco BS-4 or Saber MSB115S2 (550W)
Hafco AL320G Lathe
Saber Bandsaw
24th May 2019, 07:11 PM #10Member: Blue and white apron brigade
- 7,183
28th May 2019, 09:09 AM #11Diamond Member
- Sydney, NSW
- 1,249
I've moved house and workshop many times. I simply have a image in my head and then try and put it in to action. Then I move everything around several times until I'm happy. Generally the workshop ends up looking the same, lathe and mill on one wall, work table and tool storage on the other and everything else scattered around.
Ben.
28th May 2019, 10:57 AM #12Member: Blue and white apron brigade
- 7,183
28th May 2019, 03:48 PM #13Most Valued Member
- Australia east coast
- 2,713
29th May 2019, 01:09 PM #14
Home workshop layout
By Stephen H in forum METALWORK GENERALReplies: 19Last Post: 25th Apr 2014, 01:35 AM -
Layout
By China in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACKReplies: 1Last Post: 21st Aug 2013, 02:26 AM -
Layout blue
By morrisman in forum METALWORK GENERALReplies: 9Last Post: 30th Sep 2012, 05:21 PM -
where to buy layout dye
By welder in forum METALWORK GENERALReplies: 11Last Post: 14th Jul 2011, 06:38 PM -
The new layout
By zenwood in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACKReplies: 72Last Post: 15th Jan 2007, 07:39 AM
