Results 1 to 14 of 14
    Oct 2015
    melbourne
    473
    Default Tapered fitting to shaft
    My mate has a chipper/mulcher.
    It threw a blade which bent the crank.
    Removing the cutter disk from the crank, which is a taper fitting locked with an axial bolt proved extraordinarily difficult even with a gear puller. (bent the plate...)
    The plate was off not long ago so I was surprised how difficult it was.
    Even removing it after assembly (which was when the bend was found) was difficult.
    He used grease on the shaft. Is this correct /ok/bad?
    Russ
    Apr 2012
    Healesville
    2,129
    It sounds a bit of a odd bod to me Russ, I lost count a long time ago of how many chippers that I have had to repair and they all had a parallel shaft and a key.
    Generators have a tapered shaft and the odd pump may have also.
    Typically you don't lube a taper as when you tighten the bolt that pushes the whatever onto the taper and it normally has a torque spec to push it on so far/tight and that would likely be dry unless otherwise specified.
    So I think you need to hunt those details up, what make and model is it?
    cheers, shed
    Oct 2011
    Norwood-ish, Adelaide
    59
    6,559
    I vaguely recall our mulsher (5hp Briggs and Straton) had a taper shaft on it.
    Grease on the shaft would make it easier to push the tapered socket up the shaft for a given torque, so probably not recommended if you want to disassemble easily.
    Dec 2005
    South Australia
    1,657
    If I were to put any thing on the taper I would use never seize
    Mar 2009
    54
    825
    G'day Russ,
    When refitting aluminium flywheels on tapered lawnmower motor cranks I always dust the shaft with some graphite, this helps with smoother seating of the taper when torquing the retaining nut and makes them easier to remove next time.
    Greg.
    Apr 2012
    Healesville
    2,129
    When you assemble a shaft coupling it helps to undersand what is it actualy doing, how does it work......
    Most of the forces on it are torsional, but in this instance you also have shock forces and vibrational forces and aslo significant enertia forces when these forces oppose each other.
    So a tapered shaft coupling is basically 2 opposing tapers forced together with a nut or bolt to form a compression joint that relies on friction between the 2 mating tapers to transmit torque.
    So what do you think will happen when you add a lubricant to this coupling that relies on friction to transmit torque?
    If it is a part that needs to be removed often for maintenance then drill and tap a hole either side of the boss to utilize a puller that wont bend the blade carrier. Something that will put pressure on then a spot of heat and the taper will let go.
    Dont go bashing the thing as you can crack the crankcase on the engine under the flywheel.
    Cheers, shed
    Oct 2015
    melbourne
    473
    Oops
    My bad...brain freeze... Tapered fitting to shaft
    It is of course a straight shaft with keyway. I have no idea where the idea of a tapered shaft came from. Tapered fitting to shaft
    If it was a taper it would release almost immediately it moved but we had to use the puller almost the whole length.
    Definitely impact load but it wasn't run after the blade was replaced, the bent crank was noticed and it was removed again. And seemed to be even tighter...
    Russ
    Apr 2012
    Healesville
    2,129
    Russ it needs to be a fairly tight interferance fit otherwise the key and keyway will flog out.
    It would likely also flog out if you put never seize on it, i have seen this a few times where mowing contractors put never seize on the disc bosses to aid in removal, they fairly soon become a sliding fit on the shaft and the keys and keyways flog out.
    At installation i would just give it squirt of wd40 to help it slide on.
    The cranks can be hard to hold to straighten depending on the orientation of the bend in relation to the balance weights.
    I have also been able to straighten a couple with a strategic wack with a copper hammer, you dont do this with the crank in the engine.
    If you need a crank there is a slim chance i might have one if it is a briggs engine???
    Cheers, shed
    Jun 2007
    Vic
    48
    544
    I have removed a few taper fitting in the past with the homemade extractor. while the bolt on the extractor is under pressure, I use copper mullet to tap on the end of the bolt gently...
    Oct 2015
    melbourne
    473
    Cheers, shed
    Shed , it's a 5.5hp b&s.
    Be spectacular if you do... Tapered fitting to shaft
    Russ
    Apr 2012
    Healesville
    2,129
    Quote Originally Posted by russ57 View Post
    Russ
    No, sorry nothing that small.
    If you dont have the tools to straighten it and you need a hand with the repair let me know.
    cheers, shed
    Oct 2008
    N.W.Tasmania
    1,407
    Quote Originally Posted by jackaroo View Post
    What, The fish or the haircut???
    Oct 2011
    59
    6,559
    The fish obviously. Getting hold of a bogan with red hair is difficult at the best of times.
    Jun 2011
    Australia east coast
    2,713
    Not round here, it's not.....
    PDW
  1. Tapered Reamers
    By DonkeyBoy in forum METALWORK GENERAL
    Last Post: 12th Apr 2016, 03:46 AM
  2. Tapered BSP threads.
    Last Post: 16th Jun 2015, 09:03 PM
  3. 1:20 Tapered reamer
    By Ueee in forum METALWORK GENERAL
    Last Post: 16th May 2013, 11:53 AM
  4. Bluing a tapered shaft
    By jack620 in forum METALWORK GENERAL
    Last Post: 9th Apr 2013, 07:02 PM
  5. 5/8 tapered pin reamer
    By azzrock in forum THE HERCUS AREA
    Last Post: 18th Nov 2010, 08:03 PM
