Results 1 to 10 of 10
Thread: Vice Parallels
    Oct 2011
    Sydney, NSW
    1,249
    Default Vice Parallels
    Hi,
    I was browsing ebay the other day and seen these:
    https://www.ebay.com.au/itm/QUADRALL...T/192880892790
    Gimmick or the real deal?
    Ben
    Nov 2017
    Geelong, Australia
    57
    2,665
    I think the concept is sound. I saw online somewhere the idea of using a ball bearing between the work and the vice moving jaw during initial squaring operations where the 2 clamping faces aren't yet parallel. I've done it many times and it works well.
    This tool is really just an extension of that concept.
    7,188
    I've seen two largish magnetised nuts and a ballbearing employed in a similar way. However, the wider flats would have a bit more friction and hence holding power.
    Jun 2007
    sydney ( st marys )
    64
    4,890
    You can also use a piece of ground bar on the moving jaw or a piece of bright, you just want to reduce the contact surface area that the plain jaw face would provide.
    Nov 2007
    melbourne australia
    3,228
    It's hard to see $152 plus postage in that tool.
    Tune in here at 6 minutes for some other ideas: https://www.youtube.com/watch?v=tW8HNAlUXxU
    Apr 2012
    Healesville
    2,129
    They should be called "Vice Unparallels"
    Oct 2011
    Norwood-ish, Adelaide
    59
    6,559
    You could make something similar with a ball bearing using the cone from a large drill bit (that is, use the tip to drill enough for a cone to act as a seat).
    It looks reasonable in theory but my concern would be whether there is a tendency for it to slip out the end. Steel on steel has a coefficient of friction of around 0.05 from memory, so any clamping angle over 2.8 degrees runs that risk.
    7,188
    I thought it was a bit more but it seems like there's not a lot of agreement about what it is.
    https://hypertextbook.com/facts/2005/steel.shtml
    Mar 2014
    South of Adelaide
    1,227
    You need better glasses. There would be at least 1 hour to make that, at shop rates thats $80-100, springs, material and heat treat would cover the remaining $50.
    Nov 2007
    melbourne australia
    3,228
    My glasses are fine. Given that they have already sold 18 units I just assumed they are using jigs or CNC to make them. So they should be fairly quick to make. I'd be surprised if it was an hour. I also figured they are heat treating them in batches, so I'm not seeing $50 there. I guess they have to cover the time to make the jigs or program the CNC. In any case, plenty of people seem willing to pay the money, so good luck to them.
  1. carter no 4 vice , pipe vice,triton saw holder
    By robyn2839 in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 27th Nov 2018, 04:27 PM
  2. odd parallels
    Last Post: 2nd May 2017, 10:38 AM
  3. Self Setting Parallels for the Drilling Vice
    By metaler in forum METALWORK GENERAL
    Last Post: 25th Jan 2017, 07:23 AM
  4. 1-2-3 Blocks as Parallels?
    By simonl in forum METALWORK GENERAL
    Last Post: 10th May 2013, 08:15 PM
  5. Milling Parallels
    By Oldneweng in forum METALWORK GENERAL
    Last Post: 31st Jan 2013, 05:29 PM
