Results 16 to 28 of 28
21st May 2019, 06:12 PM #16Golden Member
- Vic
- 48
- 544
I am just turning them around for you...
21st May 2019, 06:42 PM #17Novice
- May 2019
- North Perth
- 23
21st May 2019, 06:51 PM #18Golden Member
- Vic
- 48
- 544
Not telling ...I am using Photoshop to turn them around. Smartphone and PC are "smart" enough to put the photo into the right orientation when viewing but not the forum. Forum uses "script" and database to upload->store->link the image but not displaying like the application does in windows.
21st May 2019, 07:16 PM #19Most Valued Member
- Healesville
- 2,129
Peter wind the crank around and situate the con rod furtherest to the rear, so that the blade frame is as far back as
it will go and then have a look at the sliding ways on the top of the frame and see if they are all the way back.
Then wind the crank 180 deg to bring the blade frame as far forward as possible and see if the blade frame ways are
are protruding out of the front.
What i am thinking is that the connecting rod might be too long, and a cut n' shut might solve your problem.
cheers, shed
21st May 2019, 07:41 PM #20Senior Member
- Jun 2005
- Townsville, Tropical Nth Qld.
- 226
I had the clunker going today and I had confused myself with the abrasive cutter, it is movable but the Parkanson is not. I rang my older sister as we both operated it (times were tough in the sixties) and her memory is better than mine, she said dad had made a solid steel spacer with an edge on it to hook on the back jaw edge.
Tootsie, one thing you need to make is a series of spacers to move the steel you are cutting between the back jaw and the moving jaw to maximize you blade usage. I had a photo of this in a previous thread, but I can't retrieve it from the files?
Good luck, great old machines.
Rgds,
Crocy.
21st May 2019, 08:06 PM #21Senior Member
- May 2019
- Picnic Point, Sydney
- 77
- 314
It surprises me that the cutting stroke pushes against the moveable vice jaw. I could set my old Taiwanese clunker to cut the same way by rotating the lifting cam so I'm wondering if your hacksaw has a similar function to convert it to a pulling cut.
On the holding bit ... whether 90 or 45 degrees you should always support both vertical faces.
21st May 2019, 10:56 PM #22Novice
- May 2019
- North Perth
- 23
21st May 2019, 11:21 PM #23Novice
- May 2019
- North Perth
- 23
solved, this is what forums are about!
0
Crocy
your sister is right, attaching to back jaw is the go but I will bolt a spacer on there is already a hole there and I can drill another. Can do the same re blade usage but not as worried about that yet. Love the old beast already, working on it quickly gives an attachment, the rhythmic sound, smell of coolant, low temperature cutting and it was cheap!
Thanks mate I think this is a problem solved, now I just have to get photo uploading sorted!
cheers Peter
22nd May 2019, 12:18 PM #24Most Valued Member
- Healesville
- 2,129
You can solve your problem the easy way with packers but that does not repair the fault in the saw.
I would be interested to know why probably thousands of these were made and they can't cut a 45?
Personally I would find and fix the fault.
Cheers, shed
23rd May 2019, 09:46 AM #25Novice
- May 2019
- North Perth
- 23
Cutting short lengths
Off thread a bit but found an old manual for a different PHS and it explained the hole in the left side of the movable jaw. It is there for cutting from stock that is shorter than half the jaw width. You use a bolt to connect from back jaw to face of front jaw in place of contact with missing stock.you can see the hole in this photo.75281768-1552-44FC-BB00-7128C347CD83.jpg
23rd May 2019, 12:34 PM #26Novice
- May 2019
- North Perth
- 23
here is a picture taken with iPad using portrait. It’s not upside down!
23rd May 2019, 12:42 PM #27Novice
- May 2019
- North Perth
- 23
Cut and shut
Thanks, yes the rod is too long but I would rather pack the jaws than cut it. I have read that some PHSs have holes enabling rear jaw to move forward for angle cuts and to use more of the blade. Mine doesn’t have these. If I get sick of packers I might hire a magnetic drill and try that.
Cheers peter
23rd May 2019, 01:53 PM #28Most Valued Member
- Healesville
- 2,129
Parkanson Power Hacksaw Oils
By Rodeoclown666 in forum METALWORK GENERALReplies: 9Last Post: 30th Jul 2022, 01:53 PM -
By Mk1_Oz in forum METALWORK GENERALReplies: 50Last Post: 14th Nov 2020, 07:17 PM -
SOLD: PARKANSON Power Hacksaw
By harty69 in forum METALWORK - Machinery, Equipment, MARKETReplies: 5Last Post: 15th Jul 2013, 07:52 PM -
Parkanson power hacksaw
By Dave J in forum METALWORK GENERALReplies: 60Last Post: 18th Feb 2012, 08:09 PM -
restoring parkanson power hacksaw
By mistercartoon in forum METALWORK GENERALReplies: 29Last Post: 2nd Jul 2010, 09:31 AM
