Page 1 of 2 12 LastLast
Results 1 to 15 of 28
    May 2019
    North Perth
    23
    Default Parkanson Power Hacksaw 45 angle cut
    Have acquired a Parkanson PHS and want to cut some angle iron at 45 degrees. The vice allows this but the material doesn’t then fall within the blade stroke. Tried putting packing behind the angle iron to bring it within the cutting stroke but the material keeps coming loose. The saw cuts on the forward stroke and lifts on back stroke.
    Suggestions please.
    I am really happy with square cuts and have cut lots of square tube and solid square and round bar. I have put a new single phase motor in and am using a small electric fountain pump for coolant as the original was missing. Made a replacement motor cover and Have started repainting the machine green with Rustoleum but may start again with POV15 as I used it on an old lathe and am very impressed.
    May 2011
    Murray Bridge S Aust.
    5,959
    Hi and Welcome to a TOP FORUM.
    When you pack the angle out, do you put a packer inside the angle, so that the angle is supported on both sides.
    Would it be possible to take a pic of how you set it up to cut, PLEASE?
    Just makes it easier to see how things are done rather that visualisation.
    May 2019
    North Perth
    23
    Default Thank you
    I have hurt myself and can’t set up a photo but I will ponder packing inside the angle. Is there any way of lengthening the cutting stroke? Or something else I haven’t considered.
    cheers
    May 2011
    5,959
    So that I could cut 45 degrees and 90 degrees, without having to reset the fixed jaw, I made a 45 degree block, that went up against the fixed jaw. You could do the same and pack it out enough to clear the back/front of the blade.
    HTH
    Dec 2011
    Buderim qld
    40
    Don’t want to put this thread off track, but were Parkanson machinery made in Australia? Are their Power Hacksaws sought after?
    May 2019
    North Perth
    23
    Default Parkanson power hacksaws
    Quote Originally Posted by Kidbee View Post
    They were made in Melbourne, I bought one so sought after by some. They are lovely machines especially in comparison with grinders and they don’t heat the metal as they cut it and are relatively quiet. Extremely heavy but they settle into a workshop and give it a certain gravitas. But back on thread, does anyone know how to make angle cuts with one of these dinosaurs?
    cheers Peter
    Apr 2012
    Healesville
    2,129
    Quote Originally Posted by TootsieB View Post
    Suggestions please.
    Does it have an adjustable crank pin, see if it has a T slot on the crank wheel.
    Some photo's of the other side of the saw would help, also a pic or 2 showing the problems when set to 45 deg.
    cheers, shed
    May 2019
    North Perth
    23
    Default More on vice
    cheers, shed
    Here are some photos, they’re inverting, sorry don’t know why and can’t find a tool to rotate them.
    Aug 2015
    QLD
    735
    ...they settle into a workshop and give it a certain gravitas...
    Apr 2012
    Healesville
    2,129
    Can you get a pic of the right side of the saw and a pic of where the connecting rod attaches to the crank.
    cheers, shed
    May 2019
    North Perth
    23
    Default Photos
    cheers, shed
    Photos on not working well may be inverted. I took these earlier before your post so not the crank.
    May 2011
    5,959
    We need pics of the crank arrangement, to ascertain if it's possible to alter the stroke.
    Jun 2005
    Townsville, Tropical Nth Qld.
    226
    On my pre WW2 clunker there is only one crank pin. Haven't cut 45 deg for over 30 years but something in my head says you have to move the back post forward. I will have a look tomorrow.
    rgds,
    Crocy
    May 2019
    North Perth
    23
    Quote Originally Posted by Old Croc View Post
    rgds,
    Crocy
    Crocy thanks that sounds like a possibility. I am having difficulty getting photos to work on any thread.
    Cheers Peter
  15. #15
    May 2019
    North Perth
    23
    Default Crank pin
    Cheers Peter
    Had a look at the crank can’t see any way of adjusting it.
  1. Parkanson Power Hacksaw Oils
    By Rodeoclown666 in forum METALWORK GENERAL
    Last Post: 30th Jul 2022, 01:53 PM
  2. Parkanson Power Hacksaw
    By Mk1_Oz in forum METALWORK GENERAL
    Last Post: 14th Nov 2020, 07:17 PM
  3. SOLD: PARKANSON Power Hacksaw
    By harty69 in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 15th Jul 2013, 07:52 PM
  4. Parkanson power hacksaw
    By Dave J in forum METALWORK GENERAL
    Last Post: 18th Feb 2012, 08:09 PM
  5. restoring parkanson power hacksaw
    By mistercartoon in forum METALWORK GENERAL
    Last Post: 2nd Jul 2010, 09:31 AM
