Results 1 to 4 of 4
    Jun 2007
    Vic
    48
    544
    Default Hydraulic vice fluid
    Hi All,
    I want to give this hydraulic vice a service. Does anyone know how do I top up the fluid and what fluid is suitable for it? There are 2 bolts to hold it in the body and a small M6 bolt in the opposite end with a copper washer, I am wondering if this is the bleed hole?
    Thanks,
    Trong
    Jul 2016
    35
    1,522
    I don't know how to bleed it unfortunately but any 40 to 60 ish hydraulic oil will be fine, I buy mine in barrels from Supercheap.
    Jun 2007
    Vic
    48
    544
    I just had a go at at, the piston appears to be a 10mm rod in diameter, there is some fluid left inside so I am hoping the seal is still good. I still need to find a way to take the main main screw apart and I have no clue yet! There is another secondary screw inside with finer thread pitch, that is to push the rod against the piston of the hydraulic.
    Regards,
    Trong
    Jun 2007
    Vic
    48
    544
    I am using 68 and it seems to work. I had this vice for 8-9 years and I never knew that it was possible to adjust the jaw opening in 3 positions. I even bought a bigger vice just to swap out for anything that didn't fit in it. I glad that I gave it a service.
  1. carter no 4 vice , pipe vice,triton saw holder
    By robyn2839 in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 27th Nov 2018, 04:27 PM
  2. Hydraulic Vice
    By KBs PensNmore in forum METALWORK GENERAL
    Last Post: 23rd Oct 2018, 11:43 PM
  3. Layout fluid
    Last Post: 21st Oct 2017, 05:58 PM
  4. Layout fluid
    By section1 in forum METALWORK GENERAL
    Last Post: 3rd Feb 2017, 11:35 PM
  5. Vice Stop ( or why the vice is still not painted Michael )
    Last Post: 5th Jan 2016, 09:01 PM
