Results 46 to 48 of 48
Thread: Swivel head band saw thoughts
16th Apr 2019, 12:38 AM #46Novice
- Oct 2018
- Australia
- 58
- 21
16th Apr 2019, 09:49 AM #47Cheers.
Vernon.
16th Apr 2019, 11:10 AM #48Philomath in training
- 6,541
It does to a degree - the jaw furthest away from the swivel most of all obviously. However, if you think about it, it is not much worse than cutting straight - the material still needs to be long enough to be in contact with the front jaw. On my saw maybe 20mm at 45 degrees?
There are ways around this if cutting short stock though. I normally use a piece of RHS and a spacer on the other end of the jaw to 'extend' the back jaw across in this case. I also have a few other bandsaw jigs that allow me to cut shorter stock more easily as well.
Swivel head vice threads
By Grahame Collins in forum METALWORK GENERALReplies: 15Last Post: 25th Oct 2018, 02:38 PM -
$50 3" swivel milling vice review
By BobL in forum METALWORK GENERALReplies: 8Last Post: 2nd Jun 2018, 03:20 PM -
How to calculate the size of base required for a swivel crane?
By Alexxred in forum WELDINGReplies: 12Last Post: 15th Mar 2017, 11:09 PM -
SOLD: Machine levelling feet with swivel 20mm stud.
By Greg Q in forum METALWORK - Machinery, Equipment, MARKETReplies: 3Last Post: 14th May 2013, 08:43 AM -
Swivel Base Revisited
By Anorak Bob in forum METALWORK GENERALReplies: 100Last Post: 8th Oct 2012, 02:33 PM
