Results 1 to 15 of 18
Thread: Replacement Power Feed Gear
10th Apr 2019, 08:29 PM #1Golden Member
- Jan 2016
- Wodonga Vic
- 38
- 633
G'day everyone,
I'm chasing a replacement plastic power feed gear for a Hafco HM 52 milling machine for my local Men's Shed, the gear came out of the X axis power feed box.
They've tried Hare & Forbes and didn't have any luck and I've tried eBay and found 4 common types but none of them match up to the part that came off the power feed unit, one is close, but not quite.
Dimensions are:
OD = 92.8mm
ID = 45.8mm
Thickness = 13mm
Photo:
The one that's close:
https://www.ebay.com.au/itm/Milling-...e300%7Ciid%3A1
Any help tracking down a replacement would be greatly appreciated.
Thanks.
10th Apr 2019, 08:40 PM #2Most Valued Member
- Jul 2016
- 35
- 1,522
I cant quite tell from the photo is it a helical gear? Do you know what module it is and what the tooth count is?
One of us can probably make it if you cant find a replacement
10th Apr 2019, 08:51 PM #3Philomath in training
- 6,541
Post it over. I'll make you one.
(It's helical and I get a tooth count of around 109t, so probably around 30 DP/ 0.8M)
10th Apr 2019, 09:10 PM #4Golden Member
- Jan 2016
- Wodonga Vic
- 38
- 633
Thanks Michael,
You're correct, it has 109 teeth, but I'm not sure about it being helical, it looks straight cut to my eye (Edit: straight cut at an angle that is) but being so small I could be wrong.
I'll post it over, I'm not sure if I still have your address, could you please send it via PM.
Ben
10th Apr 2019, 10:54 PM #5
I also have the HM52 and bought 4 or 5 gears from the US years ago when our dollar up and before postage went up, but won't fit one of my power feeds as I have 3.
I found this seller on AliExpress some time back and and saved it in case I need it for that one.
The shop caters for all brands, and at $33 for 5 it's not worth making one.Using Tapatalk
10th Apr 2019, 10:58 PM #6
I didn't screen shot it, but it's free shipping to Australia.
I don't speak highly of Machinery House, but to not carry spares for there own machines. They would probably charge you $80-$120 if they did have it.Using Tapatalk
10th Apr 2019, 11:04 PM #7
Just found another seller I saved, free postage as well
Using Tapatalk
10th Apr 2019, 11:06 PM #8
Forgot one with the price
Using Tapatalk
10th Apr 2019, 11:46 PM #9Golden Member
- Jan 2016
- Wodonga Vic
- 38
- 633
Do you think it might be the ASONG gear? https://www.ebay.com.au/itm/Milling-...2F-TfnhM7UHrQg
I did consider it but the OD is about 0.8mm undersized and it's 1mm thicker, although it does have the right amount of teeth...
What do you blokes think?
11th Apr 2019, 08:59 AM #10Diamond Member
- Feb 2013
- Laidley, SE Qld
- 1,038
Thanks for the link Dave J, for 30 odd dollars I'll buy 5 of those Asong gears for just in case.
11th Apr 2019, 09:31 AM #11
11th Apr 2019, 09:33 AM #12
11th Apr 2019, 01:41 PM #13Golden Member
- Jan 2016
- Wodonga Vic
- 38
- 633
I've ordered 5 ASONG gears to try out, if they don't fit the Men's Shed power feed unit I'll sell them to somebody here who can use them.
Thanks for the offer Michael, if it doesn't work out I'll accept your offer to make a replacement.
Ben
11th Apr 2019, 02:18 PM #14
The measurements you took and what what advertised where so close, so I think you will be fine
Many years ago people wrote up about getting a spare gear with them.
The power feed companies used to have a spare gear in the bottom cap as there are clips in them to hold it, but I didn't get one in any of mine. I guess they cut costs.
I can't remember which brand of mine needed a spare.Using Tapatalk
11th Apr 2019, 05:37 PM #15
I just looked and the one Im missing a spare for is the ASONG as it was factory fitted to the mill like the one your working on.,
The 5 I bought from the US (Shars I think it was) where these ALSGS ones, as that's the other 2 power feed brands on my mill. The mailing box is dated February 2013, so I guess they will last nearly a lifetime if I'm careful lolUsing Tapatalk
B&D Power file roller replacement
By KBs PensNmore in forum METALWORK GENERALReplies: 12Last Post: 8th Mar 2018, 04:06 PM -
Replacement bevel gear buy or make suggestions needed
By Com_VC in forum METALWORK GENERALReplies: 9Last Post: 16th Oct 2017, 11:42 AM -
Power Feed
By Auskart in forum METALWORK GENERALReplies: 22Last Post: 30th Dec 2016, 08:23 PM -
DM 45 power feed
By morrisman in forum METALWORK GENERALReplies: 32Last Post: 2nd Feb 2012, 10:34 PM -
power feed for a HM-45
By Sterob in forum METALWORK GENERALReplies: 2Last Post: 2nd Oct 2006, 08:34 PM
