Results 1 to 15 of 44
Thread: Parting tool
9th Apr 2019, 04:37 PM #1Senior Member
- Nov 2012
- Mid North Coast NSW
- 422
Parting tool
Question :
What is the best, most forgiving type of parting tool ?
9th Apr 2019, 04:55 PM #2
I personally like the Armstrong style parting tool holders. The ones with the "spring" head.
YMMV.
Edit - like this ARMSTRONG-USA-No-32-R-LATHE-PARTING-TOOL-HOLDER.jpgCheers.
Vernon.
9th Apr 2019, 05:13 PM #3Member: Blue and white apron brigade
- 7,183
The T - cross section parting tools seems to leave the others for dead.
9th Apr 2019, 05:59 PM #4Most Valued Member
Agree with Bob with the caveat that it needs to be a good one like the cobalt ones from Eccentric Engineering with the hollow ground top surface.
9th Apr 2019, 06:47 PM #5Senior Member
- Nov 2012
- 422
What about this type ?
https://www.ebay.com.au/itm/QA-Parti...tvUn2DFTZtVTEg
9th Apr 2019, 06:59 PM #6Philomath in training
- 6,541
There is nothing special with respect to that holder - it just holds a carbide tip. Depending on your lathe, it might be rigid enough to use a carbide parting tool or it may not. Carbide tips are usually not as sharp as HSS and so a smaller lathe may not have the grunt to use them. They are also wider than a knife tool for example, so if you think cutting forces, they are higher. Any parting tool must be set so it is cutting on centre.
If you have a lathe with a few kW then carbide is an option but otherwise I would stick with HSS. Carbide is not as forgiving as HSS as it normally breaks rather than blunts or bends
MichaelLast edited by Michael G; 9th Apr 2019 at 07:00 PM. Reason: added a bit
9th Apr 2019, 07:25 PM #7
Hi Phaser, Guys,
I use a ridged rear mounted blade. The cross section is a "V" shape and is 1/16" thick at the top. Easy to sharpen the flat front face. I do admit to having broken the end off the blade a couple of times, forgetting to wind the blade out before moving the saddle.
My holder and the data on the blade.Best Regards:
9th Apr 2019, 07:50 PM #8Mechanical Butcher
- Oct 2004
- Southern Highlands NSW
- 1,894
[QUOTE=Vernonv;1948508]I personally like the Armstrong style parting tool holders. The ones with the "spring" head.
YMMV.
Agree, these work well for me too.
9th Apr 2019, 07:54 PM #9Diamond Member
- Jun 2010
- Canberra
- 1,322
I'm far too inexperienced to give any kind of meaningful opinion on parting tools, only that with my new lathe, I got me this one:
Seems to work fine on steel, but when I was parting off a series of bronze bushes, it tended to gouge as I fed it in, kind of taking up the backlash each time I turned the cross slide. I tried re-positioning it slightly above centre, but it didn't help. The bushes all parted off fine, but the gouging action was a bit off-putting.
9th Apr 2019, 08:02 PM #10
Wrong insert for bronze/brasses.
Otherwise a nice tool but more expensive than a HSS blade !Best Regards:
9th Apr 2019, 10:25 PM #11
I agree with this type of parting blade and had great results.
I've never tried rear mount running in reverse, but will get around to it one day when I decide to drill my lathe cross slide
Quality HSS (as you have) helps a lot over most of the Chinese rubbish sold as HSS parting blades.Using Tapatalk
9th Apr 2019, 11:26 PM #12
Hi Dave,
Don't attempt to run the lathe in reverse ! The parting tool should be upside down !
This has the advantage that swarf tends to fall out of the cut and not jam the blade. I also use Temaxol or Trefolex on the blade as a cutting lubricant. Because both these products are pastes they stick to the blade and melt as the blade gets hot. I also use Diesel and WD40 on aluminium materials.Best Regards:
9th Apr 2019, 11:40 PM #13
15th Apr 2019, 08:08 PM #14Senior Member
- Nov 2012
- 422
This is impressive. Might be what I need if I can find one the right size.
I'd be looking at 2 of them, one for the mini lathe and one for the AL350 :
https://www.youtube.com/watch?v=E2h5eexVE_0
15th Apr 2019, 08:47 PM #15
That looks great, but he does have a rigid machine.
Always wondered why the factory supplied carbide parting tips don't come sharpened with the right side higher, so the part comes off first nice and flat and the nib is left on the stock and removed after the part has left.
I always sharpen my HSS this way.Using Tapatalk
parting tool geometry
By brendanh in forum METALWORK GENERALReplies: 19Last Post: 25th May 2015, 06:58 PM -
parting off... or should I say ..how to break the parting off tool
By eskimo in forum METALWORK GENERALReplies: 19Last Post: 19th Mar 2014, 02:29 PM -
Parting off tool ?
By morrisman in forum METALWORK GENERALReplies: 5Last Post: 10th Oct 2013, 11:36 AM -
Your best parting tool
By iron bark in forum METALWORK GENERALReplies: 61Last Post: 20th Dec 2012, 07:40 PM -
Parting tool mounted on rear tool post advice needed
By colbra in forum METALWORK GENERALReplies: 17Last Post: 12th Feb 2012, 02:49 PM
