Results 1 to 15 of 21
9th Apr 2019, 03:05 PM #1Senior Member
- gold coast
- 303
Availability of 7/8 X 14 UNF round stock--
HI everyone,
I am hoping to be able to buy about 500mm of Imperial threaded stock in steel 7/8 X 14 UNF
Does any still exist in Australia?
I don't have any way of turning an imperial thread, and what's more my tradesman ship in that area leaves a bit to be desired.
I will appreciate any suggestions please
regards
Brian'
9th Apr 2019, 03:31 PM #2Most Valued Member
- Jul 2016
- 35
- 1,522
Do you need it threaded the whole length?
9th Apr 2019, 04:22 PM #3Gear expert in training
- 34
- 1,075
Google is your friend. Here you go https://www.bolt.com.au/mild-steel-r...1818_1824.html
9th Apr 2019, 05:31 PM #4Senior Member
- gold coast
- 303
CW--I need pieces about 70mm long (sorry 2 3/4 inches) threaded the whole length. I could cut them from bolts, now you jogged my thinking.
Any ideas where i could buy them?/
Thanks for the heads up on Google, who is often my friend, but $116 is a little too rich for the value of the job, Im sorry. It's just me messing about with some ideas
regards
Brian
9th Apr 2019, 06:05 PM #5Philomath in training
- 6,541
You may be better off going to a specialist fastener store and asking for 7/8" UNF studs, 3" long
9th Apr 2019, 07:02 PM #6Member: Blue and white apron brigade
- 7,183
A few years back our local fastener shop had imperial UNF sizes up to 1" x 36" in all thread rod.
9th Apr 2019, 07:26 PM #7Golden Member
- Jul 2011
- 837
9th Apr 2019, 07:34 PM #8Diamond Member
- Mar 2014
- South of Adelaide
- 1,225
+1 for united fasteners. At work we find they are the best for larger imperial fasteners. You wont be able to buy just 500mm. you will have to buy a 3ft length.
10th Apr 2019, 06:15 PM #9Most Valued Member
If you really get stuck i can offer to source the stock (assuming 7/8" is a stock size) in bright and thread and cut to size.
If its not standard BMS I would need to know what type of steel and also the class of thread you want.
You would just have to pag for the material and postage from melbourne.
11th Apr 2019, 10:15 AM #10Most Valued Member
I just priced some 7/8" round bar in bright from my local steel supply and it's $13.50 per metre. I forgot to ask if that included GST so it may end up $14.85 incl GST but either way it's not too expensive in the quantities you need.
11th Apr 2019, 11:18 AM #11Most Valued Member
which supplier is that Simon?
11th Apr 2019, 04:45 PM #12Most Valued Member
K & K steel.
Frankston - Flinders Rd. Hastings.
12th Apr 2019, 11:04 AM #13Diamond Member
- Feb 2013
- Laidley, SE Qld
- 1,038
I have 7/8" 1045 round at Laidley 4341, I can spare enough for your project if that helps. Cutting a 14tpi thread in 70mm lengths is possible, pm me.
13th Apr 2019, 09:53 PM #14Senior Member
- gold coast
- 303
Thank you all--everybody for your kind support
Thanks Bob for your generous offer for help.
Ive put the project on hold for the immediate present. I may need to follow this up in a month or two.
In the mean time I got myself stumped trying to source a few 3 inch (75mm) lengths of 5/8 inch X 26 TPI in MS (which I have been told is a British Brass Thread by the ancient "Toolie" in the village.
Any suggestions Brains Trust??
warmest regardsd
Brian
14th Apr 2019, 08:48 AM #15Philomath in training
- 6,541
That one you may have to make. I can't see a modern fastener supplier stocking that one. You might try
https://www.classicfasteners.com.au/
and see what they can find (or know of)
L00 backplate availability
By morrisman in forum METALWORK GENERALReplies: 1Last Post: 24th Jul 2018, 08:28 PM -
Drilling and tapping jig for round stock.
By aametalmaster in forum METALWORK GENERALReplies: 18Last Post: 8th Mar 2012, 09:09 PM -
making square stock round on a metal lathe
By 19brendan81 in forum METALWORK GENERALReplies: 17Last Post: 19th Apr 2010, 09:20 PM -
Round and squire bar stock wanted
By STEAM in forum METALWORK GENERALReplies: 4Last Post: 2nd Nov 2008, 10:04 PM -
Metal availability
By MathewA in forum METALWORK GENERALReplies: 12Last Post: 16th May 2005, 05:02 AM
