Results 1 to 5 of 5
Thread: Magnefying table
9th Apr 2019, 08:46 AM #1Novice
- Apr 2019
- Queensland
- 12
Magnefying table
Years ago I saw a device for magnefying outlines. It had all lenses and mirrors. You put the tool on the table and looked at it on a light screen magnified and to scale. There must be similar things now using cameras and screens. Does anyone know of such a thing?
9th Apr 2019, 09:19 AM #2Most Valued Member
- Jul 2016
- 35
- 1,522
What you are looking for is called a number of different things, but optical comparator or shadowgraph should get you what you want.
9th Apr 2019, 11:18 AM #3Diamond Member
- Feb 2013
- Laidley, SE Qld
- 1,038
Or on a larger scale, if signwriters wanted to make a sign that included a big version of say a customer provided small emblem, they would fix a sheet of sign material to the wall of the shed, use a projector device to throw an enlarged image of the emblem onto the sheet, then paint to the image.
This was pre scanners computers and CNC sign cutters of course.
9th Apr 2019, 02:40 PM #4Philomath in training
- 6,541
This will do something similar to what you want I think -
https://www.officeworks.com.au/shop/...racer-ja212780
10th Apr 2019, 10:58 PM #5Golden Member
- Dec 2007
- 574
I worked for a sign writer some (many) years back and he had a device called an epidiascope - rotating a lever on the side opened a door (just smaller than A4 size) on the bottom - an image or anything reasonably flat for that matter was then placed on the door the lever was rotated back - the door lifted and shut and an enlarged image of the object was projected onto a screen/wall etc. focusing and image sizing etc worked the same way a slide projector.
How big is the thing you are wanting to magnify ? you might want to checkout USB microscope they can display an enlarged image onto a lcd screen or even a mobile phone they can go to over 1000X, ebay is a good place to start looking.
Welding table
By node105 in forum WELDINGReplies: 7Last Post: 18th Aug 2018, 10:58 PM -
X - Y table
By Petip in forum METALWORK - Machinery, Equipment, MARKETReplies: 1Last Post: 22nd Apr 2017, 08:40 AM -
Box tubing clamp for holding table leg to table frame
By 19brendan81 in forum METALWORK GENERALReplies: 4Last Post: 11th Jan 2017, 12:05 PM -
FixturePoint Welding Table 900 x 600mm Table
By dradyz in forum METALWORK - Machinery, Equipment, MARKETReplies: 2Last Post: 26th May 2016, 01:38 PM -
DM 45 table stops
By morrisman in forum METALWORK GENERALReplies: 18Last Post: 17th Feb 2012, 05:26 PM
