Results 46 to 60 of 168
Thread: H&F Mini Lathe Vs Ebay
12th Apr 2019, 10:00 AM #46Most Valued Member
I think you might have it backwards John:
Left Hand Cutting Tool and Right Hand Cutting Tool
Sorry if I misunderstood you.Chris
12th Apr 2019, 11:27 AM #47Most Valued Member
- 4,887
In regards to the chuck jaws if the chuck and jaws are not already numbered engrave or stamp the numbers 123 on the jaw and also mark the chuck so you know where to put the jaws, number 1 will always be first and so on.When you insert the jaw firstly turn the chuck key or what ever method is used to get the start of the chuck scroll visible then back it off a touch insert chuck jaw and the turn the key to engage the jaw, you may need to apply a little pressure to the jaw to make sure the chuck scroll engages, then turn the key until the start of the scroll appears at position 2 and repeat procedure for 1 and then do the same for 3.
In regards to which handle or part of the machine to use for longitudinal turning, that will be governed by how long the machined section needs to be,just be mindful that the carriage normally runs parallel to the bed/ spindle and the compound slide can be set at a angle to cut a taper, if you are going to use the compound slide for longitudinal turning you will need to make sure that it is parallel to the spindle, normally down with the use of a dial indicator.
12th Apr 2019, 03:21 PM #48Most Valued Member
- Aug 2009
- Sydney, NSW, Australia
- 1,836
Thanks guys help and advice is much appreciated
I needed to turn the job around because my cut off tool can only cut around 8 to 9mm i needed to cut deep enough thru the 36mm bar to cut it off which was not going to work so i turned the piece around
EDIT: i measured my tooling and it was 6mm i thought it was 8mm, is this a good cut off tool? https://www.ebay.com.au/itm/6mm-Self...e/392246843990 i only need 4 pieces to do all the work i want, 1 is to machine the face and the side (tool came with lathe), another is a drill bit to drill a 10mm hole (need to purchase a drill bit set), the boring tool for the hole enlargement (came with lathe works brilliant but emits a high pitch squeal), Cut off tool (yet to buy link above)
12th Apr 2019, 06:32 PM #49
Last edited by BaronJ; 12th Apr 2019 at 06:45 PM. Reason: I've corrected the error ! Thanks Chris.
12th Apr 2019, 06:41 PM #50
It is as good as any other ! As long as it will fit into your tool holder it should be OK.
only need 4 pieces to do all the work i want, 1 is to machine the face and the side (tool came with lathe), another is a drill bit to drill a 10mm hole (need to purchase a drill bit set), the boring tool for the hole enlargement (came with lathe works brilliant but emits a high pitch squeal), Cut off tool (yet to buy link above)Best Regards:
12th Apr 2019, 07:14 PM #51Most Valued Member
- Aug 2009
- 1,836
Thanks Baron i just tried looking up the tool names not easy to find in google pictures, looks like i was using a inside threading tool as a boring tool which they both look very similar just the boring tool has a square on the cutting tip the and threading tool is pointed my bad but it still worked great
i think i may need to buy a new set of tools in a case one of each and start fresh take pictures of each tip so i know what they look like and how to resharpen them
the tools that came with my lathe were half a packet of the square tools 6x6mm HHS and some odd round tooling than needs shimming kind of looks like old taps cut down and made into lathe tools
12th Apr 2019, 07:15 PM #52
Totally agree about using HSS, I have a 300x900mm lathe and still use it, especially on aluminum and gummy mild steel. On both I can get great finishes
For you size lathe I would highly recommend it, as it needs less HP as well because it's razor sharp after honing.
I find a cheap eye glass works great to see you cutting edge sharpening.Using Tapatalk
12th Apr 2019, 08:20 PM #53Most Valued Member
- Aug 2009
- 1,836
Ok i will buy the hhs bars i need some practice on the shaping and sharpening here is my attempt it worked for a bit than went blunt
I can confirm i was boring using the threading tool rookie mistake
12th Apr 2019, 09:21 PM #54
If they are going blunt really quickly you, sounds like your spindle speed is to fast. Slow it down, it's not like carbide.
Also some of the Chinese HSS is crap, try to buy good Australian, British, or USA HSS though eBay. It really is that much better.
HSS at lower rpm and slow feed for finishing will leave a nice surface finish.
You can hog at a higher feed rate.Using Tapatalk
12th Apr 2019, 09:37 PM #55
Just to add, a normal fine bench grinding wheel will do, but use a oil stone to hone the edge. A cheap oil stone will do, but use something to magnify it to see your honing taking away the grinder marks making it nice and smooth razor edge.
The more you do it the easier it gets and most times the tool only needs a hone rather than a grind to resharpened it.
A little radius helps with a a nice finish, do that with the stone rolling it around the edge to suit your tool.
.Using Tapatalk
12th Apr 2019, 09:44 PM #56Most Valued Member
- Aug 2009
- 1,836
Is it ok to sharpen both ends of a tool to minimise cost?
I have been sharpening using a angle grinder but i was just watching a video on youtube and the guy was using a bench grinder i will have to pick up a bench gronder tomorrow they are cheap at bunnings
While watching youtube videos one person said the parting tool stick out should be no more than the diameter of the tool in my case that will be 6mm i cant cut anything with 6mm i need 15mm stick out there abouts
12th Apr 2019, 09:52 PM #57
Supercheap have little bench grinders on special at the moment, $30 I think they where which I thought was cheap when I seen them.
Yes sharpen both ends is no problems, most of mine are, with me though I have tool holders for each tool, so turning them around means resetting tool height.Using Tapatalk
12th Apr 2019, 09:56 PM #58Most Valued Member
- Aug 2009
- 1,836
For the hss tool can u cut and sharpen a round hss 6mm drill bit from bunnings the Sutton brand? I am really egar to get machining and the ebay sellers are quoting 12 days shipping from SA to Sydney
I seen that Dave super cheap has them for $30 bunnings $35
12th Apr 2019, 09:56 PM #59
With the parting tool, buy a HSS parting tool holders and blade, they are deeper than your square HSS.
You may have to modify or get someone to weld a piece of 6 mm on the side so mount it to your lathe toolpost.Using Tapatalk
12th Apr 2019, 11:29 PM #60
These days I wouldn't use those drill bits, but could work depending on how far up they are HSS. Most are made in China these days.
Be patient, look on eBay for new/used/okd stock quality HSS if you can . Otherwise try to buy Chinese HSS with cobalt, it will be better.
You will still have a wait time. Aussie tools may have some in Australia.
I was very lucky with having a market close to me with Indian sellers selling all lathe tooling cheap, including HSS bits which where pretty good. Doesn't compare with the Australian/US/ British stuff from many years ago that I have.Using Tapatalk
Mini Lathe
By Mutawintji in forum METALWORK GENERALReplies: 32Last Post: 25th Apr 2013, 01:35 PM -
SOLD: The Mini Lathe
By Big Shed in forum METALWORK - Machinery, Equipment, MARKETReplies: 1Last Post: 30th Jan 2011, 10:23 AM -
Mini Lathe
By elderly in forum METALWORK GENERALReplies: 12Last Post: 1st Dec 2010, 09:21 PM -
Mini Lathe
By dj_pnevans in forum METALWORK GENERALReplies: 1Last Post: 22nd Apr 2010, 11:46 PM -
Mini Lathe
By Bodgy in forum METALWORK GENERALReplies: 6Last Post: 6th Aug 2005, 11:50 PM
