Page 12 of 12 FirstFirst ... 2789101112
Results 166 to 168 of 168
  1. #166
    Aug 2009
    Sydney, NSW, Australia
    1,844
    Thanks Baron absolutely love this lathe having a bunch of fun with it, i was umming and arring if i should place the cutting tip 45 or 90 degrees will there be any flex if i go 45? While i was machining the 6mm diameter i noticed the thin end was ever so slightly flexing but it was pulling back into line and machining
    Do u think i can use the round allen head lock bolt or should i get the M5 grub screw?
  2. #167
    6,475
    Hi Gazza,
    It hardly matters which screw you use ! As long as it doesn't interfere with the work piece or the chuck.
    One trick I have used with a much larger diameter round boring bar used to get into a fairly deep blind hole, is to drill through the threads of a cap screw, just under the head, in my case a 1/8" inch round carbide pin and screw it into a threaded hole in the end of the boring bar. The idea being to trap and secure the toolbit with the screw.
  3. #168
    Aug 2009
    1,844
    That might be easier Baron, i also changed the speed of the machine its about 40% quieter
  1. Mini Lathe
    By Mutawintji in forum METALWORK GENERAL
    Last Post: 25th Apr 2013, 01:35 PM
  2. SOLD: The Mini Lathe
    By Big Shed in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 30th Jan 2011, 10:23 AM
  3. Mini Lathe
    By elderly in forum METALWORK GENERAL
    Last Post: 1st Dec 2010, 09:21 PM
  4. Mini Lathe
    By dj_pnevans in forum METALWORK GENERAL
    Last Post: 22nd Apr 2010, 11:46 PM
  5. Mini Lathe
    By Bodgy in forum METALWORK GENERAL
    Last Post: 6th Aug 2005, 11:50 PM
