Results 16 to 25 of 25
Thread: Gearbox needle roller housing.
21st Mar 2019, 05:34 PM #16Banned
- Jan 2019
- 78
Thanks for that, I have a very high pressure, pressure cleaner and a blasting cabinet, I would assume those two plus the acetone would suffice. Jap castings are a little better than the old Triumph/BSA/Norton castings, not as porous so hopefully those three will do the job. However, I was thinking about distortion from the heat. the XS is split gorizontally rather than vertical and the needle roller housing is very close to the jointing surface. I may have to just bite the bullet and search for a second hand set of cases. Expensive, but maybe less messing around.
The damage appears to have been caused by a thrown up rock or a loose chain as I can see no other damage aside from the needle roller housing and the top section of the crankcase halves.
The needle roller housing is just under the section that has been broken off. Looking at it now, I think a replacement case is the best way around it. The bike was a barn find, possibly laid up for quite a few years by the look.
21st Mar 2019, 05:44 PM #17Banned
- Jan 2019
- 78
I've had a good look around since discovering the broken housing but can't see any other damage and it kicks over without any worrying noises. Once I get the carbs cleaned up I'll push the go button, that'll tell me more.
The bike was a barn find and looks like it's been languishing in a barn for quite a few years. Unfortunately, the XSs are getting expensive now so a donor bike is out. I got this one quite cheap but, chances of getting another are zero. Still, this is a life project, I'll never be able to ride it due to a broken body; heck, I have trouble pushing the damn thing, just a hobby to keep me off the streets.
I can get a set of cases for around $300 from the states, that's $99 for the parts and the rest for postage, so much for the US mail - damned expensive! Might be the best option I'm starting to think.
21st Mar 2019, 10:01 PM #18Most Valued Member
You haven't mentioned the size of the bike, but found a XS 250 that's being wrecked and close too, if that's any help.
Will be going to Adelaide hopefully on Saturday, can pick it up and drop off if need be?
21st Mar 2019, 10:55 PM #19Banned
- Jan 2019
- 78
Its a 650, so different bike. Thanks anyway.
21st Mar 2019, 11:02 PM #20Golden Member
- Jul 2011
- 837
22nd Mar 2019, 10:44 AM #21Banned
- Jan 2019
- 78
Yep, thinking about it.
23rd Mar 2019, 11:17 AM #22
I noticed an ad in ‘Old Bike Australia’ mag that may help with parts.
Geoffs XS.
Just google that and his site comes up.
They did an article about him a while back and he seems knowledgeable and into XSs.
H.Jimcracks for the rich and/or wealthy. (aka GKB '88)
26th Mar 2019, 05:03 PM #23Senior Member
- Dec 2011
- Deception Bay Qld
- 111
There is a Xs club and a Facebook group in oz plus the Vjmc , plenty of guys will have parts bikes.
27th Mar 2019, 10:20 AM #24Banned
- Jan 2019
- 78
Yep, I'm a member of all the facebook groups, the Aussie XS club and aware of Geoff's XS, Mkes and Retro and a few others.
27th Mar 2019, 11:18 PM #25Diamond Member
- N.W.Tasmania
- 1,407
4me you have clearly taken offence at something that you have read into PDW's response for advice. While he may sometimes appear a bit blunt, (I didn't think his response to you was, it was just a no nonsense and straight answer) he certainly does know what he is talking about, as anyone who has seen the 12 metre steel yacht that he has scratch built, including machining bronze porthole castings, machining all the steering gear, lots of aluminium bronze there, welding the hull, all the fixtures etc etc. Not to mention the fitting out, engine installation wiring, plumbing and finishing, - there are pictures on this site if you care to look.
I also thought that you were referring to a combination mill drill for the machining, not a welding machine, but again I think PDW is likely to be pretty close to the money on the welder front as well.
There are many very cluey and experienced members on this forum, and you would do well to listen to what they are trying to tell you, and not just toss out a load of insults. If you think that a pressure washer will do the job of cleaning a casting to the point where a wipe with acetone will be sufficient to weld it, then you will either be very very lucky or more likely disappointed. Have another look at what Michael G has advised, he is another very talented member of the group, who knows what he is talking about. I am not a welder, but I have seen just how difficult castings can be to repair, especially if they have been exposed to oil or grease, and while Honda castings are likely of good quality, getting them clean will be no easy task just the same.
Finally I would wish you good luck with a repair, if successful it should be cheaper than replacement cases, remember, post up some pictures of the work in progress, and the completed job. There is a saying on the forum "If there are no pictures, it hasn't happened."
Bearing housing build up
By newmanwoodlands in forum METALWORK GENERALReplies: 5Last Post: 28th Oct 2017, 10:08 PM -
Needle bearing for Hercus lathe spindle.
By flmath in forum THE HERCUS AREAReplies: 2Last Post: 4th Jun 2017, 04:49 PM -
Welder near Glen Iris Vic who can weld triton power saw housing back together?
By barrysumpter in forum WELDINGReplies: 1Last Post: 11th Jan 2017, 03:59 PM -
Fixing leak in Alloy Pump Housing
By Abratool in forum METALWORK GENERALReplies: 20Last Post: 3rd Mar 2014, 11:03 PM -
Needle scaler
By lornety in forum WELDINGReplies: 6Last Post: 25th Jun 2010, 10:43 PM
