Results 1 to 13 of 13
18th Mar 2019, 10:19 AM #1Member
- Aug 2016
- 80
woodfast / steelfast vertical bandsaw
Anyone know what the differences are between woodfast timber bandsaw and steelfast metal bandsaw other than the reduction gearbox on the steelfast?
I'm after a BS mainly for metal but they are harder to find than and I wonder if slowing a woodfast BS down would be essentially the same.
18th Mar 2019, 10:50 AM #2Member: Blue and white apron brigade
- 7,183
It depends what you are cutting - if its just Al, brass or similar then even a WW BS will do that.
From memory the Steelfast is a sturdier build.
I found a Steelfast for the mens shed and have used it to cut curves in sheet steel but apart from that I don't think much of them and for other cutting would much rather use my 6 x 4 horizontal bandsaw I have at home. Safer, Easier to clamp, cuts without standing there holding the material, turns itself off when finished, and can be set up to run lube coolant.
18th Mar 2019, 11:09 AM #3
I would say the differences are:
1.
The final blade feet per minute figures - metal as compared to timber meaning you shall need to modify the pulley system or add the reduction gearbox to achieve the 275 to 350 FPM standard needed for most metal blades.
2.
The drive wheels - bare metal for metal blades as compared to rubber tyre for timber blades.
3.
Modern Metal cutting saws commonly have roller bearing blade guides where most Woodfast bandsaws may not have them which means yet more modification.
The conversion is certainly doable. If I was going to that much trouble I would look at a VFD set up which might be cheaper in the long run.
A lot of people choose the versatile horizontal saws some of which lend themselves vertical blade cutting.
18th Mar 2019, 11:33 AM #4Member
- Aug 2016
- 80
I'd like to cut steel mostly. Cutting bar stock for the lathe as well as sheet. Was thinking vertical for the versatility and I only have space for one type of machine
18th Mar 2019, 12:16 PM #5Golden Member
- Jul 2011
- 837
I am working on a couple of Steelfast ones at the moment. The gearbox is the main difference. The guides in the Woodfast are brass but in the Steelfast they are steel but they would be trivial to swap. The differences in the base are because the gearbox moves the pulleys out further from the main casting.
The gearbox on the Steelfast is 18:1 if you like I can measure up the stepped pulleys too. It has 4 grooves in the motor and driven pulley. (I assume we are talking about the 14" Steelfast units?)
BTW both units have the same cast aluminium rubber tyred bandwheels. The steelfast unit can be taken out of back gear to cut wood at up to 1100 Metres per minute yet in back gear it can get down to about 30 Metres per minute Which is probably good enough for cutting stainless.
You wont get that kind of range in speed with a VFD alone.
18th Mar 2019, 12:31 PM #6Golden Member
- Jul 2011
- 837
18th Mar 2019, 12:32 PM #7Member
- Aug 2016
- 80
If it's not too much trouble it would be interesting to know the full pulley ratios.
There's a woodfast in a current auction that I think is 14", has the rounded design on stand. I'd prefer to just buy a steelfast but haven't found the right one at the right price yet.
18th Mar 2019, 02:07 PM #8Member: Blue and white apron brigade
- 7,183
In that case the horizontal bandsaw beats the vertical by a long way.
Especially since horizontal saws can be operated unattended and with lube.
neither of these saws cut very fast but you don’t want to be standing for minutes and applying constant pressure all this time. Holding longer pieces becomes problematic. With a horizontal saw you can cut 1 mm off the end of a meter long bars with considerable ease and accuracy.
18th Mar 2019, 03:53 PM #9Golden Member
- Jul 2011
- 837
I have been thinking of buying that one for a spare because nearly all its parts are interchangeable with the Steelfast and the price is so cheap (at least last time I looked). Also came with a heap of woodworking blades. I have actually 3 steelfast saws hoping to make two good ones out of each. All three have dodgy gearboxes so be prepared for some work if you find one (they actually come up quite regularly though as evidenced by the fact I have got hold of three in less than 6 months).
20th Mar 2019, 03:13 PM #10Member
- Aug 2016
- 80
What's been the issue with the gearboxes?
20th Mar 2019, 05:30 PM #11Philomath in training
- 6,542
The design has a flaw in it such that if the blade and/or the belts are over tensioned, it tends to flog out the bores of the gears, as well as wear the shafts. All repairable but a pain never the less, especially if you are expecting things to work smoothly from the get go.
In hindsight, think if I were the designer I would incorporate an outrigger bearing to stablise things - I suspect that it was one of those quick/cheap changes to expand the product range. Adding a gear box is simple but this particular design is not terribly robust in the longer term.
20th Mar 2019, 06:57 PM #12Golden Member
- Jul 2011
- 837
20th Mar 2019, 07:43 PM #13Philomath in training
- 6,542
14" Steelfast/Woodfast Bandsaw
By lamestllama in forum METALWORK GENERALReplies: 22Last Post: 27th Dec 2018, 07:59 PM -
Vertical Bandsaw - Convert Wood to Metal ?
By electrosteam in forum METALWORK GENERALReplies: 6Last Post: 13th Dec 2017, 09:03 PM -
SteelFast Bandsaw
By Petip in forum METALWORK GENERALReplies: 28Last Post: 18th Jun 2014, 01:43 PM -
horizontal/vertical bandsaw adjustment..
By Corgan in forum METALWORK GENERALReplies: 19Last Post: 18th Aug 2011, 09:56 PM -
Horizontal/Vertical bandsaw
By Stustoys in forum METALWORK GENERALReplies: 12Last Post: 17th Jul 2010, 08:18 PM
