Results 1 to 8 of 8
Thread: Hollow drill bit !
17th Mar 2019, 09:12 PM #1
Hollow drill bit !
How many times have you put a wood screw into something and have had the head break off ?
I started to put a new latch plate on the kitchen door recently. Unfortunately I had not chiselled out quite enough wood from behind it, so I started to remove the two wood screws that I had used and both screw heads broke off leaving the shank in the wood frame with no way of gripping them in order to get them out !
A little frustrated after spending 15 minutes or so trying to dig enough wood away to get a pair of grips on them, I gave up and decided to make a hollow drill bit and get them out that way. On the basis that I can always put a wooden plug into the hole, I set to and made this drill bit.
I used a 70 mm long piece of 1/4" silver steel to make this drill.
I drilled it using a 4 mm drill, down the centre, then slotted it for a distance of about one inch starting 6 mm from the end with a 3 mm slot drill. After I then used a 1.5 mm slot drill to cut six teeth in the end, after which I hardened it by heating with a cooks torch until the end was cherry red then plunging into a cup of water. I then tempered the end to take the glass hardness off.
The teeth were cut by eye and are not a uniform as they could be. Setting the rod over by 20 degrees with a piece of plywood wasn't the best way either But it worked well enough.
The idea behind the slot is so that any wood lodged in the drill can be removed with a probe. In actual use a couple of digs with the drill bit allowed both the screws to be removed without too much trouble. I filled the holes that were left with dowel, glued and tapped into the wood frame.Best Regards:
18th Mar 2019, 12:00 AM #2Most Valued Member
- 5,945
What a brilliant idea. You should start manufacturing them, now, before the Chinese see it and start making them from wet spaghetti. You'd have no trouble selling them, everyone breaks off screw heads.
18th Mar 2019, 12:35 AM #3China
- Dec 2005
- South Australia
- 1,656
Interesting I have used plug cutters in the past to do that
18th Mar 2019, 03:26 AM #4
Hi China, Guys,
Thanks for reminding me ! I have a set of plug cutters, in a box under my nose
I just looked at them the smallest is 3/8" inch bore, but I doubt that they will cut more than a few MM deep.Best Regards:
18th Mar 2019, 07:43 AM #5Most Valued Member
Nice work John. What sort of wood screws are you using that break off when you un-screw them? Whenever I buy Chinese made hardware I usually throw the screws away and replace them with a quality screw of similar size.
This guy makes a version of your saw with a piece of golf club shaft. Less elegant than yours, but very effective:
https://www.youtube.com/watch?time_c...&v=bD6ibqWpVCMChris
18th Mar 2019, 04:32 PM #6Gear expert in training
- 34
- 1,075
+1 for plug cutters, done that trick several times.
Sorry to bust your business plans, but long ones have been around for a long time as well https://www.infinitytools.com/boring...non-cutter-set
18th Mar 2019, 08:39 PM #7
Hi Elan,
No plans to bust, sorry
Now maybe twenty years ago I might have been tempted !Best Regards:
19th Mar 2019, 04:00 AM #8Senior Member
- Aug 2007
- 292
Nice job on the extractor. There are commercial versions around without the side slot ejector.
https://www.highlandwoodworking.com/...xtractors.aspx Cheaper places to get them from if you look around.
I remember reading a tip someplace where the gent used roll pins to make his extractors. If sized just right it would follow the screw in a little and grab it turning it out of the wood, left hand driven naturally. It made the smallest hole to plug.
Pete
Where to get 3/8"-24 hollow studs?
By FenceFurniture in forum METALWORK GENERALReplies: 10Last Post: 27th Oct 2015, 11:05 PM -
Looking for a piece of hollow bar
By jhovel in forum METALWORK GENERALReplies: 13Last Post: 15th Jul 2013, 02:40 AM -
Marking out hollow bar
By Bidgee in forum METALWORK GENERALReplies: 13Last Post: 27th Oct 2011, 11:30 PM -
Hollow Sphere
By xplsives in forum METALWORK GENERALReplies: 11Last Post: 13th Dec 2006, 04:02 PM
