Results 1 to 15 of 17
15th Mar 2019, 09:40 PM #1Member
- Nov 2015
- Brisbane Australia
- 85
Speed calculator on a dial for a lathe
As you do on a rainy Friday night I was perusing through the used lathes on ebay and came across a Swedish lathe with a great idea, I have not seen one before but it does imperial feet/ minute and metres/ minute.
You move the dial to the diameter and cutting speed for the metal, rotate to suite and it tells you on the bottom how fast to have the machine.
Being the novice I am I think it is a great idea.
Maybe the picture didn't come out but here is the link to the Ebay page
If you zoom in on the left you will see what I am talking about.
Big Metal Lathe - BOSS says SELL CHEAP | eBay
15th Mar 2019, 10:06 PM #2Pink 10EE owner
- 6,216
The Macson 18/21" swing lathes had a dial thing on the headstock. I think it was some sort of spindle speed calculator.
15th Mar 2019, 11:13 PM #3Golden Member
- Nov 2010
- Gippsland Victoria
- 733
If you like it you could maybe make one out of two pieces of paper or cardboard and keep it beside your lathe.
I've seen another graphical calculator you might find useful with material type, cutting speed and diameter shown on three straight parallel lines knowing any two you can draw the line connecting two points to estimate the third
https://vanhack.ca/lib/exe/fetch.php...ting-speed.png
Am sure it is in one of the basic beginners turning books but cannot find it on my shelf, the above link shows a version of it.
This sort of graph is called a nomogram. Have done some googling but cannot find the version I am thinking of.
Bill
16th Mar 2019, 07:03 AM #4Philomath in training
- 6,541
Here's another one
At one stage I was going to make a copy but I find (especially with my lathe) that just because you can run work that fast does not mean it is practical - flex, chatter, shape all conspire to mean that you need to cut speed.
17th Mar 2019, 01:54 PM #5Most Valued Member
- 5,945
That's a good point Michael, but for a beginner, it's a good starting point, as it would vary according to the lathe, overhang of the tool, and many other variables.
18th Mar 2019, 04:50 PM #6Most Valued Member
When I first started turning I felt I really needed a quick and easy spindle speed guide, so I made up an excel spread sheet and printed it out. The horizontal rows had the desired speed in M/min, the vertical columns had the diameter of the material and the corresponding cell contained the required RPM for the correct surface speed.
I hardly use it now. I go by initial guess and then feel.
18th Mar 2019, 05:37 PM #7Gear expert in training
- 34
- 1,075
Here's the nomogram from the standard TAFE textbook "Fitting and Machining"
What I really want is a feed chart; I can usually pick a good speed, but getting the chips to break nicely and leave a good finish as well is still very hit-and-miss for me.
It seems to be affected by tip radius as well, are there any rules-of-thumb?
18th Mar 2019, 07:55 PM #8Most Valued Member
- 4,887
Don't exceed the nose radius.
18th Mar 2019, 08:00 PM #9Gear expert in training
- 34
- 1,075
But the only way I'm getting a bright finish is by going deeper than the nose radius
0.5-1.0mm deep on a 0.4 rad comes up better than grinding, but 0.2 deep on the same tool comes out chewed up and horrible.
EDIT: Never mind, that's depth, not feed.
18th Mar 2019, 08:07 PM #10
18th Mar 2019, 09:14 PM #11Most Valued Member
- 4,887
18th Mar 2019, 09:17 PM #12Most Valued Member
I did similar to Simon when I started out. Fitted a tacho to the lathe and made a table of RPM vs stock diameter for various materials. Not long after I removed the tacho and threw out the table. I now make an educated guess of RPM based on the type of material, its diameter and the tool doing the work. Set the VFD and start cutting. Adjust RPM as required to give a nice finish or stop the chatter when parting off.
I actually found some of the recommended speeds and feeds didn't work. I suspect they are designed for much more rigid machines than my Hercus 260.Chris
18th Mar 2019, 10:12 PM #13Most Valued Member
- 4,887
It's theory.
19th Mar 2019, 12:27 AM #14Golden Member
- Nov 2010
- 733
I often get a very good finish by turning the knife tool around to present a flat edge to the workpiece and take a tiny fluff cut. Sometimes doc can be as little as pushing slightly on the toolpost with my hand.
If you want to be geometrical about it that is an infinite tip radius and a microtadge depth of cut.
Bill
19th Mar 2019, 03:48 AM #15Senior Member
- Aug 2007
- 292
Search for machining apps and download one or two to your cell phone. Some basic ones are free and the better ones cost a few bucks. Now you have the info for lathes, milling, drilling, tapping and shop math in your pocket. They are designed for industry and carbide so you may want to be less aggressive depending on your machine but they get a newby like me in the ball park.
Pete
Taiwan belt driven lathe gear/thread calculator
By familyguy in forum METALWORK GENERALReplies: 0Last Post: 19th Nov 2018, 11:41 AM -
Pulley and Belt size speed ratio Calculator
By KBs PensNmore in forum CONVERSIONS & CALCULATIONSReplies: 0Last Post: 4th Dec 2017, 08:50 PM -
Lathe thread cutting change gear calculator
By Vernonv in forum METALWORK GENERALReplies: 61Last Post: 20th Dec 2015, 08:38 AM -
Variable Lathe spindle speed control project for constant surface speed
By jhovel in forum METALWORK GENERALReplies: 27Last Post: 15th Oct 2014, 08:34 AM -
SOLD: C2 Variable Speed Lathe
By SurfinNev in forum METALWORK - Machinery, Equipment, MARKETReplies: 3Last Post: 2nd Apr 2011, 06:06 PM
