Results 16 to 17 of 17
19th Mar 2019, 12:41 PM #16Golden Member
- Nov 2010
- Gippsland Victoria
- 733
Picture for Kryn
Kryn,
See attached.
From "The Amateur's Lathe" by L. H. SParey - great book.
At the moment am using a knife tool with no rake and turn it all the way around so the complete flat rubs against the workpiece - works fine. Maybe it shouldn't work but it does on my lathe (Hercus 9")
If you want the tiniest cut and don't want the hassle of turning the topslide around to a high angle if you just push slightly on the toolpost with your fingers - that's enough to give a tiny dust cut.
Bill
19th Mar 2019, 07:51 PM #17
These pictures show the shear tool that I often use. If you notice it is also a right hand lathe tool rotated towards the chuck. The hight is not at all critical, if it wears you just move the tool up or down to get a new edge. That edge is set at about 35 degrees. Honing the edge helps as well.
For what its worth, I've also used a tool similar to make a grub screw flat on a shaft ! Lazy I know, I could have done the same with a file.Best Regards:
Taiwan belt driven lathe gear/thread calculator
By familyguy in forum METALWORK GENERALReplies: 0Last Post: 19th Nov 2018, 11:41 AM -
Pulley and Belt size speed ratio Calculator
By KBs PensNmore in forum CONVERSIONS & CALCULATIONSReplies: 0Last Post: 4th Dec 2017, 08:50 PM -
Lathe thread cutting change gear calculator
By Vernonv in forum METALWORK GENERALReplies: 61Last Post: 20th Dec 2015, 08:38 AM -
Variable Lathe spindle speed control project for constant surface speed
By jhovel in forum METALWORK GENERALReplies: 27Last Post: 15th Oct 2014, 08:34 AM -
SOLD: C2 Variable Speed Lathe
By SurfinNev in forum METALWORK - Machinery, Equipment, MARKETReplies: 3Last Post: 2nd Apr 2011, 06:06 PM
