Results 1 to 9 of 9
Thread: Drilling Copper
    May 2006
    Canley Heights, NSW
    67
    529
    Default Drilling Copper
    What is the best way to drill 3mm & 4mm copper plate without it catching, holes are 1/4" up to 1" .
    Shane
    Got the square peg in the round hole, now can't get it out !!
    34
    1,079
    Putting a neutral rake on the cutting edges would probably help with the grabbing, it works in brass.
    Jul 2006
    Athelstone, SA 5076
    4,258
    Clicksprings shows how to do it for brass...i reckon it would be the same for copper
    Oct 2011
    Norwood-ish, Adelaide
    59
    6,559
    If the material is only thin, a shallower drill point angle will also help (135 degrees or even more if you can do it. You really need to get the tips cutting before the point breaks through.
    I've been told that milk is a good cutting fluid for copper. Never tried it (maybe one day )
    Nov 2007
    melbourne australia
    3,228
    I would think a stepped drill bit would work. They work beautifully on sheet that is too thin to use twist drills on. For 4mm sheet you might need to come in from both sides. I have some copper sheet. Never tried drilling it though. Let me know if you want me to try it.
    Nov 2017
    Geelong, Australia
    57
    2,665
    Stepped drill bits work well on soft thin materials as the rake is pretty neutral. Just don't use one of the style with a helix in the flutes.
    A center drill might be an option for smaller holes or just put a tiny zero/reduced rake on the cutting edge of your drill with a diamond stone.
    I'd use holesaws for the larger sizes.
    May 2011
    Murray Bridge S Aust.
    5,959
    Being a soft material, you could try a Forstner bit forstner bits.jpg as used for wood, I know they work on aluminium OK. When the point just breaks out the other side, turn the piece over and drill from the other side.
    I used Inox spray as a lubricant.
    If a particular odd size is required, they can be ground down to suit. I did mine with a flap disc on a 4" grinder on my Drill Press, just make sure the cutting side is larger than the shaft side, I had about .5mm clearance.
    I've found using a hole saw, sometimes leaves markings around the edge until it starts cutting.
    Nov 2017
    Geelong, Australia
    57
    2,665
    Masking tape on the surface of the part or drilling through a sacrificial part (or use one with pre-drilled hole) clamped on top of the actual part can help with that.
    Jan 2004
    Mackay North Qld
    6,446
    A brad point drill or a spade bit works ok, on sheet.
  1. copper tube
    By leroy in forum METALWORK GENERAL
    Last Post: 14th Jun 2017, 07:58 PM
  2. Soldering Copper
    By chillout in forum METALWORK GENERAL
    Last Post: 13th Nov 2008, 05:53 PM
  3. Copper to copper
    By slepax in forum WELDING
    Last Post: 19th Oct 2008, 04:10 PM
  4. Machining copper?
    Last Post: 5th Nov 2007, 10:31 AM
  5. Copper tubing
    By Priemsy in forum METALWORK GENERAL
    Last Post: 3rd Aug 2007, 01:27 PM
