Results 1 to 5 of 5
    Mar 2011
    Taree NSW
    119
    Default Ward No. 7 combination turret lathe
    A friend recently bought this machine and is looking for a manual on it or someone who can advise how to cut threads on it and does it have a taper attachment - my searches on google does not mention a taper turning ability so I suspect it cant do it - any advice on this old lathe would be welcome and as I have used it myself I think he will get a lot of use out of it Regards guys
    Mar 2014
    South of Adelaide
    1,225
    I don't think they ever came with a taper turning attachment, and thread cutting requires a special attachment and a lead screw for each thread. If you can get pics i might be able to tell you more.
    Jul 2016
    35
    1,522
    Unfortunately ward in the UK are long gone but I see manuals on eBay occasionally, although usually for the larger machines. Is he planning on using it for small production runs? I don't remember if a number 7 comes with a full carriage or if you have to use box tools for turning.
    Jun 2008
    adelaide
    23
    Default Lantain 1982
    Re the Ward 7query,
    For turning tapers on a Ward 7 you had to add a taper turning attachment. This was not standard
    and was classed as an extra. Think they would be pretty rare
    Regarding screw cutting. The lathe was supplied with one "leader and nut" Dpending on what leader you have [eg leader is in fact a leadscrew.] Fore example if you had a 4 thread leader you could cut 4-8-16 pitches depending on the pitch selector quadrent. For a full range of threads you had to have 7 leaders which could give you 4 - 28 thread range. Ward also supplied metric lead screws so you need to check the pitch.
    If you PM me I can supply a copy of the screw cutting procedure.
    The Ward 7 range had a travelling saddle with cross slide and tool post attached.
    Hope this is of some help.
    Mar 2011
    Taree NSW
    119
    Quote Originally Posted by lantain1982 View Post
    Re the Ward 7query,
    Yes please lantain, this one has a travelling saddle with cross slide attached
  1. SOLD: USED SIEG M6 Lathe Mill Drill Combination
    By WillyInBris in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 27th Jan 2013, 12:12 PM
  2. Interesting Lathe-Mill Combination
    By steran50 in forum METALWORK GENERAL
    Last Post: 13th May 2012, 06:31 PM
  3. Ward 3DS Capstan Lathe Manual ??
    By Plushy in forum METALWORK GENERAL
    Last Post: 25th Mar 2009, 03:56 AM
  4. Combination Lathe and Mill
    By STEPHEN MILLER in forum METALWORK GENERAL
    Last Post: 22nd Sep 2008, 09:07 PM
  5. Combination lathe & milling machines?
    By Chris.s. in forum METALWORK GENERAL
    Last Post: 12th Jul 2005, 04:44 PM
