Results 1 to 2 of 2
Thread: Hafco HM-46 z leadscrew problem
28th Feb 2019, 01:09 AM #1Novice
- Warnbro, Western Australia
- 62
- 15
Hi all.
I've just bought a second hand HM-46 which has a fault with the z axis lead screw. The spur gear at the base of the column has popped out the alignment key and is dropping below the crank handle's spur gear.
Is anyone able to tell me the procedure for pulling the z lead screw? I want to confirm the keyway isn't damaged before attempting keyhole surgery and using the crank handle recess to replace the key.
I've attached a photo looking in through the crank handle recess. You can just make out the keyway above the spur gear.
4th Mar 2019, 04:28 PM #2Novice
- 62
- 15
In case someone else has a similar problem, the issue was the tab washer at the bottom of the leadscrew. The inner locking tab had snapped off, allowing the 16mm nut to loosen and drop off.
Half hour of filing a replacement tab washer and it's working fine.
Another Problem with my Hafco HM-46 Mill Drill
By Jarh73 in forum METALWORK GENERALReplies: 29Last Post: 23rd Oct 2018, 01:29 AM -
Hafco AL50GB belt problem
By KBs PensNmore in forum METALWORK GENERALReplies: 4Last Post: 22nd Jun 2017, 07:08 PM -
Leadscrew
By Petip in forum METALWORK - Machinery, Equipment, MARKETReplies: 3Last Post: 22nd Apr 2017, 08:38 AM -
Problem With a Hafco HM-46 Mill/Drill.
By Jarh73 in forum METALWORK GENERALReplies: 28Last Post: 23rd Jul 2012, 11:51 AM -
Hafco al-960b thread dial problem
By steran50 in forum METALWORK GENERALReplies: 8Last Post: 12th Jul 2011, 11:54 PM
