Results 16 to 17 of 17
7th Mar 2019, 07:32 AM #16New Member
- Feb 2019
- Under the basement stairs
- 43
- 2
That's a rough way to learn and I understand the frustration! I actually found someone with an XRF scanner that will scan the metal for free, so I'm super excited about that, both because I now know a place that has an XRF scanner!
Now I just need to figure out what to do with the 4' x 10' 20g 430series stainless. If i find some good uses, there's 20 more sheets available at a very good price.
7th Mar 2019, 08:50 AM #17
Hi kde5fan,
Have a careful read through this link
https://www.australwright.com.au/sta...eel-grade-430/
Note well the comments made about welding it. Basically it should be welded using the non welding arc processes, spot welding for instance.
Swaging 1.5" stainless steel tube
By bob ward in forum METALWORK GENERALReplies: 4Last Post: 30th May 2014, 02:54 PM -
1144 "StressProof" steel
By jack620 in forum METALWORK GENERALReplies: 9Last Post: 28th Jan 2013, 09:58 AM -
"Back purging" tig welding stainless sheet
By johnjohnmulley in forum WELDINGReplies: 8Last Post: 27th Dec 2009, 11:43 AM -
Difference "Galvanised" and "Primed" Steel
By Fr_303 in forum METALWORK GENERALReplies: 4Last Post: 22nd Jan 2008, 05:59 PM
