Results 1 to 5 of 5
Thread: HSS End Mill life
23rd Feb 2019, 02:43 PM #1New Member
- Jan 2015
- Newcastle
- 5
HSS End Mill life
G’day, I bought the set of HAFCO End Mill Slot/Slot Drills,used mostly the 12mm dia cutter, used on a HM36 mill/drill
What life can I expect before needing regrinding, I brush on cutting fluid and just hand feed, does touching up cutting edges help
cheers
23rd Feb 2019, 03:48 PM #2China
- Dec 2005
- South Australia
- 1,656
I am no expert although it will depend on what material you are cutting what speed you are running plus the rate of travel, it is a bit like
how long is a piece of string
23rd Feb 2019, 07:01 PM #3Most Valued Member
- Jul 2016
- 35
- 1,522
If you don't have power feed you'll just break them or chip the tips well before they actually become blunt. Otherwise it really comes down to material.
23rd Feb 2019, 08:55 PM #4Philomath in training
- 6,541
24th Feb 2019, 07:41 PM #5Senior Member
- Jul 2012
- Griffith NSW
- 435
A few things:
- HAFCO end mills = garbage. Contemplate how tight a manufacturer has to be to braze HSS cutting sections to mild steel shanks for a 6mm end mill. Of course, youre not seeing the savings from that, youre just getting the craptastic end product and paying a fortune for it.
- Life is hard to guage, but rubbing is the enemy for end mills. Take light cuts and relatively quick feeds. A 12mm end mill can cut a 6mm deep channel in one pass in theory, but your mill is not going to be able to provide enough rigidity to drive the tool like that.
- Id ditch the cutting fluid, replace it with compressed air. Oils tend to make the endmills sticky, which encourages the chip to re-enter the cut and get recut. Its essential for tool life to get the chip the hell outta there. Get one of those 7 dollar misting setups from fleabay and use that to evacuate chips. That alone will pay itself off very very quickly.
- I wouldnt bother with regrinding at that size, its not going to be economically viable. Ditch the HSS and get solid carbide end mills off ebay. 15 bucks gets you a 12mm and youll never look back at those hafco pieces of...
The Life of a Bolt
By Chris Parks in forum METALWORK GENERALReplies: 22Last Post: 11th Aug 2017, 09:13 PM -
Oxy/lpg hose life
By bob ward in forum WELDINGReplies: 7Last Post: 22nd Mar 2015, 01:36 PM -
The best things in life are free...
By sossity in forum WELDINGReplies: 4Last Post: 18th May 2014, 01:13 PM -
Arc rod shelf life.
By Optimark in forum METALWORK GENERALReplies: 29Last Post: 13th Jun 2013, 07:43 PM -
Old Steam Engine Bought to life.
By Abratool in forum METALWORK GENERALReplies: 20Last Post: 17th May 2012, 10:11 PM
