Results 1 to 12 of 12
Thread: Tru-grip chuck??
19th Feb 2019, 03:38 PM #1Most Valued Member
- 2,651
Tru-grip chuck??
Anyone seen one of these Tru-grip chucks before?
Taper is NT40, there's a small center piece inside the body and looks like there should be some type of collet to go with it.
19th Feb 2019, 04:46 PM #2China
- Dec 2005
- South Australia
- 1,656
I gave one to a mate a couple ago years ago, did not fit any thing I have it is a collect chuck I think they come in various size collects
19th Feb 2019, 06:29 PM #3Most Valued Member
- 2,651
Tru-grip chuck??
I can't find anything about it online, and its a weird design. The taper on the body would tend to spread a collet, so I'm assuming its not relevant to the clamping.
When you screw the nut on fully there is still a gap between the body taper and the nut taper, so I'm guessing the collet might have looked something like this in section:
19th Feb 2019, 09:06 PM #4Gear expert in training
- 34
- 1,075
I suspect the centre in the bottom is not for the collet, but rather as a stop for the tool so you can take it out for sharpening and put it back at the same depth to avoid having to reset your Z-axis mid job.
I found this pic of various collet styles including some old/obsolete ones, perhaps it's an E (as opposed to ER)
19th Feb 2019, 09:22 PM #5
It reminds me of the "Autolock" tool holder, particularly with the centre pin. It probably would work in a similar way ! With the right collets of course.Best Regards:
19th Feb 2019, 09:38 PM #6Most Valued Member
Clarkson chuck. I think was the first and should give plenty search hits.
Uses threaded shank milling cutters
19th Feb 2019, 09:44 PM #7Most Valued Member
P.s. the collet is threaded. The cutter screws through the collet, hits the center, forcing the collet towards to nut and this locks everything up
19th Feb 2019, 11:24 PM #8Most Valued Member
- 2,651
Definitely not a Clarkson autolock as they have a lugged base on the collet that is larger diameter than the body. This Tru-Grip has a parallel internal diameter for most of the way, then relieved slightly larger at the base where the center part is located.
Also not an E collet as they have a tapered body.
I agree that the center is more likely to be a stop for the tool than the collet though.
20th Feb 2019, 06:51 AM #9
Clarkson Autolock Chuck
These are the the best pictures that I cold find of a Clarkson Autolock on an int 40 taper.
The collet and a chuck, though I don't think that the collet fits that chuck.Best Regards:
21st Feb 2019, 06:45 PM #10Senior Member
- May 2015
- Richmond
- 214
Osborn Titanic II collet chuck.
21st Feb 2019, 09:02 PM #11Most Valued Member
- 2,651
Awesome - thanks!!
22nd Feb 2019, 06:47 PM #12Senior Member
- Jul 2012
- Griffith NSW
- 435
I had one of those mounted on an R8 shank for a chinese made mill drill toy. Granted, the mill drill was a complete POS, but I was not a fan of the collet chuck either. I could never get endmills to register on centre in the chuck, forever cutting a flute a lot heavier than the others. I ditched it for a chinese made ER32 collet and it was lightyears ahead of it. Then someone stole it and...well...I wasnt exactly upset to see it gone...
Pattern for Biax leather grip strap
By jhovel in forum METALWORK GENERALReplies: 6Last Post: 18th Feb 2016, 10:49 PM -
collets : to chuck or not to chuck
By steamingbill in forum METALWORK GENERALReplies: 4Last Post: 26th Jul 2014, 10:17 PM -
belt grip
By danielhobby in forum METALWORK GENERALReplies: 2Last Post: 5th Jun 2010, 07:01 PM -
I need a 3 jaw chuck
By BenM78 in forum METALWORK GENERALReplies: 10Last Post: 9th Feb 2010, 09:28 AM -
Vice Grip vs LockJaw
By Screwdriver in forum METALWORK GENERALReplies: 21Last Post: 16th May 2007, 07:41 PM
