Results 1 to 11 of 11
Thread: 40 taper tooling confusion
19th Feb 2019, 11:57 AM #1Most Valued Member
- 2,673
I've just entered the world of 40 taper tooling with an old TOS mill and I'm trying to work out whether I should standardise on a particular type or set the mill up to easily swap between types with different drawbars etc.
Its ISO40 natively, so has the parallel section above the taper and M16 thread. The drawbar is retained somehow - haven't investigated how as yet.
Ideally it would be nicer to just have all ISO40, but the likes of BT40 seems to be more common in industry here down under, so more likely I can pick those up used for a reasonable price.
I've got all the original ISO40 horizontal arbors, but for the vertical spindle I've only got a small mix. Couple of original ISO40 shell mill ones, a new ISO40 collet holder and collets (something uncommon - not ER) and a couple of others - one has the parallel bit above the taper but not M16 (possibly NT40), and one with just the taper so the ISO drawbar won't reach it.
Any sage advice from those of you who have already been down this road?
19th Feb 2019, 12:12 PM #2Most Valued Member
- 4,890
If the price and availability is right use both just make a draw bar to suit.
19th Feb 2019, 12:45 PM #3
I run a TOS FA3 mill and use ISO40/BT40/NT40 tooling. I simply use the appropriate threaded rod as a drawbar. I did make up a collar that I use to centre the drawbar.
I think I may have a picture of them somewhere. I'll see if I can find it.Cheers.
Vernon.
19th Feb 2019, 12:56 PM #4Cheers.
Vernon.
19th Feb 2019, 01:04 PM #5Most Valued Member
- 2,673
The FA3 looks like a nice machine - much more manual and less electrics than mine. Looking at the electrical box on mine I'm wondering if I need to adopt your tagline..
A picture would be great if you can find one.
Was your original drawbar retained or did it just pull straight out of the head?
Edit: thanks - you beat me to it with the photo.
19th Feb 2019, 01:12 PM #6Cheers.
Vernon.
19th Feb 2019, 06:53 PM #7Diamond Member
- Mar 2014
- South of Adelaide
- 1,227
If you get BT40 tooling you can make a parallel section to screw in the top to replicate ISO40. That way you don't need a longer draw bar for running BT40. use low strength loctite to stop it unscrewing.
19th Feb 2019, 07:08 PM #8Most Valued Member
- Australia east coast
- 2,713
Probably 5/8-11 TPI.
I have all variants including SK40. It's a PITA. I just use allthread to make up drawbars as needed. Plus adaptors for the various threads. After a while you have enough bits to cover the options.
40 taper is good - plenty of surface area and decent drive dogs for power transmission, readily available and not too massive like 50 taper. The real sweet spot IMO.
PDW
19th Feb 2019, 07:55 PM #9Most Valued Member
- 2,673
20th Feb 2019, 10:31 AM #10Most Valued Member
- 2,713
I have M16 to 5/8-11 and vice versa adaptors to screw into oddball holders. I found you can do quite a bit of butchery err adaptor manufacture using coupling nuts, FWIW. Just weld a short stud in one end. Loctite stud lock would probably work too but a TIG welded joint isn't going to fail.
One of my mills has a captive drawbar for M16 ISO 40 tool holders so I had to make a bunch of adaptors to use the short form holders. Once you have a bunch the pain fades a bit, though these days I try to only buy metric stuff.
PDW
20th Feb 2019, 12:38 PM #11Most Valued Member
- 2,673
Good idea with the coupling nuts - thanks.
Tumble Reverse Confusion
By pench in forum METALWORK GENERALReplies: 3Last Post: 12th Feb 2014, 09:08 PM -
40 Taper Tooling Options
By Piers037 in forum METALWORK GENERALReplies: 18Last Post: 17th Jan 2014, 12:53 AM -
MIG wire confusion
By twebb01 in forum WELDINGReplies: 19Last Post: 9th Jun 2012, 12:46 PM -
Brown and Sharpe Taper tooling for mill
By woodfast in forum METALWORK GENERALReplies: 13Last Post: 19th Apr 2012, 04:36 PM -
CONFUSION - Doorstops missing
By DanP in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACKReplies: 17Last Post: 12th Dec 2003, 12:34 PM
