Results 1 to 15 of 15
Thread: CVA upgrade
    Jul 2008
    near Warragul, Victoria
    3,723
    Default CVA upgrade
    Been thinking about my CVA no.79 mill , the spindle is the worse for wear with the morse taper end being scored badly and generally knocked about. I noticed that Tormach offer a fancy CNC style spindle cartridge with the NT30 nose , maybe I can solve my problem by adapting the new nt30 cartridge to fit into the old CVA quill ? Cost is a problem .... the Tormach cartridge ain't cheap but there is no easy fix , making a new spindle is beyond my skill level . The CVA is in good shape otherwise, I had the table ground and made a new y axis screw and nut.
    May 2011
    Murray Bridge S Aust.
    5,956
    Is it only the MT end that is the main problem, or are there other factors involved?
    If it was only the MT, then get hold of a MT Reamer and clean up that end. If you wanted to go a bit further, it could be mounted in the lathe with a steady and cleaned up with a boring bar.
    Jul 2008
    3,723
    Hi kryn
    CVA changed the spindle design in these mills at least three times during the production. Mine is a mid production 79 , it has two TRB and the MT tool end. The later CVA 79 spindle version has the NT type arbor. The spindle in mine also has damaged keyways where the pullies fit. The mill is a stout solid machine otherwise but they fitted a thin weak spindle which sort of doesn't make sense . The Lathes uk website has a CVA mill write up .
    May 2011
    5,956
    Would it be possible to open up the keyway on the shaft, and use a stepped key.
    Hopefully one of the Members here will offer to help make one for you.
    Jul 2016
    35
    1,522
    Is all you need a spindle regrind? If so I know a place that can do internal grinding that deep no issue, I have had them fix hard chromed tailstock a for me before, send me a PM and I'll get the details. Is the internal taper hardened?
    Jul 2008
    3,723
    Yes that would work. The spindle MT arbor has rather thin walls, there not much leeway for enlarging its inner diameter without weakening it. I'd prefer to go to a NT system if possible. The fact that they changed over to NT themselves may indicate there were problems with the earlier MT versions.Unfortunately these mills are thin on the ground in Aust. Seems to be more of them in the UK.
    Jul 2016
    35
    1,522
    I'm happy to turn up a spindle blank if you provide the old one. You can then hand it to the grinder. highly doubtful you will get the result you want out of what tormach have to offer. Does the. Head casting have the meat to accommodate something bigger?
    Jul 2008
    3,723
    Thanks for the offer. I will upload some pics tomorrow. The spindle has a bore down its length for the draw bar. I did draw up a basic sketch of the spindle... I will have a look
    Sep 2016
    Morphett Vale SA
    56
    27
    CVA Toolroom Milling Machine
    Looks like a nice mill,well worth repair good luck with it
    Jul 2016
    35
    1,522
    Does yours have the bronze bush or taper roller at the bottom? The through drilling would have to be done with a gun drill.
    Mar 2008
    nowra
    1,598
    I will be interested in what solution you come up with. My CVA spindle is a little scored up as well but it's still functional.
    Andre
    Jul 2016
    35
    1,522
    If the spindle isn't really hard a quick ream will give nearly all of your taper grip back. Happy to lend a MT3 reamer.
    Jul 2008
    3,723
    Default sketch
    Here is the sketch I did some years ago... the odd mixture of metric and imperial sizes is what I measured with my calipers.
    I think I could machine up a new spindle myself , some trial and error would be expected !
    Jul 2016
    35
    1,522
    If you swap the entire quill assembly out for something else, you are going to be left with the problem of getting a good honed fit in the old housing, this is not trivial.
    On the other hand turning that spindle with the thin 10" of 15/16 diameter is also not easy.
    I don't think 30 taper is going to get you that much rigidity over MT3, at least not with that quill design. I would just make the socket you have nice and clean and true.
  15. #15
    Jun 2011
    Australia east coast
    2,713
    Quote Originally Posted by caskwarrior View Post
    Agree. The only thing NT30 is going to do for you is make tool changes easier due to it not being a self-locking taper. You won't transfer more power because the spindle is too lightly built - at least it is to my eye.
    I'd clean it up & live with its limitations while looking for a heavier duty machine, if that's what you think you need. In which case I'd want a 40 taper as tooling is common & cheap.
    PDW
