Results 1 to 11 of 11
Thread: Hard milling on drill press??
16th Feb 2019, 05:55 PM #1Novice
- Apr 2007
- 16
I have some small plane blades for a vintage Woodworking plough plane that are all 6mm thick, and want to reduce the thickness to 3mm so they will work in an other plane body. (I stupidly ordered the wrong items from USA) They are hardened to about rc60 and I think are carbon steel, not hss.
Length about 80mm, width ranges from 3mm on smallest to about 30mm, and all need thickness reduced by 3mm - 0.5mm taken off the back and 2.5mm taken off front .
The only tool I have that would seem to help me is a drill press. (I think my bench grinders would be too difficult)
I was thinking of holding the blade in an xy vice and attempting to mill to required thickness in multiple passes .
Any advice on the tooling I should try this with? Or is it going to be completely futile??
One thought was to try with a CBN cup wheel .
Alternatively , anyone with a surface grinder on Sydney north side that would be willing to help would be very much appreciated .
16th Feb 2019, 06:25 PM #2Most Valued Member
- Charlestown NSW
- 1,673
Dont even bother trying to mill them, especially using a drill press.
3mm is quite a lot to take off, even using a surface grinder. Unless you paid a lot of money for them it might be cheaper and quicker to cut your losses and order in the correct size.
peter
16th Feb 2019, 06:57 PM #3Most Valued Member
Peter's right don't bother trying to mill them. Drill presses are meant for drilling, unless you have a mill/drill unit.
As also mentionedUnless you paid a lot of money for them it might be cheaper and quicker to cut your losses and order in the correct size.
At a guess, I'd have to allow about an hour each to do them, 3mm is asking a lot from a surface grinder, as they are normally used for taking off several thou of an inch or .0254 - .125mm
16th Feb 2019, 08:06 PM #4Most Valued Member
- Jul 2016
- 35
- 1,522
I would take them to a Blanchard grinding place, someone on here is related to someone that runs one but I can't remember the thread. a big Blanchard wouldn't break a sweat on this.
16th Feb 2019, 08:17 PM #5Most Valued Member
- Australia east coast
- 2,713
[QUOTE=RossM;1946547]
I was thinking of holding the blade in an xy vice and attempting to mill to required thickness in multiple passes ./QUOTE]
Complete, utter and total waste of time and fraught with risk of injury to both you and the drill press.
You *cannot* do even light milling on a drill press. There are exceptions, but that's exactly what they are. A drill press spindle is not designed to take side loads and a Morse taper isn't either. Any tooling not positively restrained by a draw bar *will* come loose if subjected to a side load, the only unknown is just how much side load and when it's going to happen.
Put this idea firmly out of mind and move on to getting the things ground or just buying more and cutting your losses.
PDW
17th Feb 2019, 03:48 AM #6
Hi Ross, Guys,
PDW is right ! You would be risking life and limb attempting to do what you suggest using a drill press.
Ebay the blades and order the right ones !Best Regards:
18th Feb 2019, 09:00 AM #7Novice
- Apr 2007
- 16
Thanks guys - I'll stop thinking about using drill press for milling!!
(Out of interest, would a CBN cup wheel in a proper mill work for this sort of activity?)
I spent some time yesterday evening experimenting on grinding using slow speed (1400RPM) grinder with 60 grit alox wheel. I managed to reduce it by about 1mm with 15 min of careful grinding, with very frequent dips in a water bath. Holding the blade by hand to judge the heat buildup. This was on an 8mm wide blade.
The blades look to only be hardened for half their length. A file skates off near the tip, but cuts OK on the rear half of the blade.
I might order a 40 grit wet stone that will fit my Tormek, that way I wont have to spend half the time cooling the blade.
It will be slow going but looks do-able.
18th Feb 2019, 10:16 AM #8Most Valued Member
- Jul 2016
- 35
- 1,522
You must be the most patient man on earth. Kudos for even giving it a go.
19th Feb 2019, 03:28 PM #9
I'm impressed with your tenacity and patience too!
I take it the planer blades a flat on both sides and the top and bottom parallel to each other? If so, if you get the thickness to within 0.5mm - even if not quite flat and with some grinding marks, I'd be prepared to sit them on my surface grinder magnetic chuck and grind them flat, parallel and to size for you. I'm really that impressed
You pay the postage though, as I'm in Victoria.... Maybe someone closer is equally impressed with your patienceCheers, Joe
20th Feb 2019, 12:04 PM #10Novice
- Apr 2007
- 16
Thanks Joe - that is a very kind offer. I have found a work colleague who has a home workshop & has offered to do this for me. Hopefully I will end up with a set of blades that work well.
I can't actually order any other blades, as the plane is very old (1870) and its nigh on impossible to find blades. The ones I ordered were reproductions for a very similar (but more common) plane. The manufacturer does not make the ones in size I need. Anyway, I'll persevere & over time should end up with a good result!
20th Feb 2019, 01:56 PM #11
Oh, good. I look ofrward to the outcome.
Cheers, Joe
Restoration Projects - Tough Drill Press - Dawn Drill Press - Record Pipe Vice
By bwal74 in forum METALWORK - Machinery, Equipment, MARKETReplies: 0Last Post: 10th Feb 2019, 03:11 PM -
Can milling machine replace a drill press
By joez in forum METALWORK GENERALReplies: 9Last Post: 29th Mar 2018, 11:04 AM -
Qld : Milling machine / drill press
By MasterSpoon in forum WANTED TO BUYReplies: 2Last Post: 15th Sep 2016, 01:16 AM -
Milling Machine vs Drill Press
By Mindabout in forum METALWORK GENERALReplies: 15Last Post: 8th Jun 2006, 10:41 PM
