Results 1 to 6 of 6
Thread: Do I need to run coolant?
10th Feb 2019, 08:10 PM #1Diamond Member
- Jun 2010
- Canberra
- 1,322
My new lathe has a coolant system, and the shop gave me a free bag of coolant concentrate, but I'm not sure when or even if I need to run coolant?
I spray a bit of WD-40 on to the job when turning aluminium to stop it sticking to the carbide insert, and use cutting fluid when drilling steel with HSS drill bits, but do I need coolant when using carbide inserts on steel?
10th Feb 2019, 08:16 PM #2Gear expert in training
- 34
- 1,079
Coolant will prolong the life of your inserts. You don't need to, but it's a good idea where practical.
10th Feb 2019, 08:57 PM #3Diamond Member
- Feb 2013
- Laidley, SE Qld
- 1,039
I don't, YMMV
10th Feb 2019, 09:23 PM #4Coolant will prolong the life of your inserts. You don'tneedto, but it's a good idea where practical.
Me, well just drip a bit of light oil on the cutting tip as I go. Also have the air nozzle handy.Frisky wife, happy life. Then I woke up. Oh well it was fun while it lasted.From an early age my father taught me to wear welding gloves . "Its not to protect your hands son, its to put out the fire when u set yourself alight".
10th Feb 2019, 09:39 PM #5
I usually use diesel/kerosene on aluminium and Temaxol, which is basically lard, sulphur and white lead, for steel, brushed on or squirt bottle for diesel. Though I do use WD40 on the circular saw when cutting aluminium. I used to have a wax stick for this.Best Regards:
10th Feb 2019, 10:16 PM #6Most Valued Member
- 4,890
When the time is right you will know to use coolant.
Coolant
By CGroves in forum METALWORK GENERALReplies: 3Last Post: 23rd May 2012, 08:35 PM -
Using Coolant
By simonl in forum METALWORK GENERALReplies: 13Last Post: 22nd Dec 2011, 10:11 PM -
which coolant ?
By Dusty Wheels in forum METALWORK GENERALReplies: 16Last Post: 1st Oct 2009, 08:06 AM
