Results 1 to 4 of 4
Thread: Finishing a rubber surface
7th Feb 2019, 06:59 PM #1Member
- Apr 2018
Hi,
I know this is a metal working forum but I know some people here also have experience working with various materials.
I am making a roller for my old planer as I cannot find an original one for sale (old machine).
Being told that it would be very expensive to have the roller re-manufactured, I decided to experiment.
I found some black rubber boat trailer rollers very cheap and machined one down to size on the lathe, after rough cutting on a band saw.
The roller is smooth after sanding but there are very minor voids and imperfections.
I guess this should be expected when machining vulcanised rubber?
Is there any sort of liquid rubber, glue or cement which can be used to smooth the surface?
I know it may not last a long time but it is surely better than having no roller at all.
7th Feb 2019, 08:21 PM #2Senior Member
- Dec 2013
- 201
Shoe Goo?
It sticks well to rubber, and leaves a nice tacky surface that would seem to be good for your application.
Graham.
7th Feb 2019, 09:43 PM #3
Probably a bit late now but I would have sanded the old roller surface to roughen it, and then used a piece of silicon rubber sheet glued on to re surface it. Being a planer, the diameter wouldn't be too critical.Best Regards:
8th Feb 2019, 12:00 PM #4Member
- Jul 2012
- Malvern East
- 84
put a small amount of rubber in a glass jar left over from the chopped up original add some toluene and allow it to break it down using small amounts of each you will come up with a rubber glue to fill the holes when finished adding the glue wrap it in aluminum foil and bake at say 140 deg c for an hour regrind to finish size
(how its done in the trade)
Good luck with it
Rubber for car restoration
By Goggomobile in forum AUTO RESTORATIONReplies: 6Last Post: 21st Aug 2019, 02:51 AM -
Do Rubber Washers Decay?
By bayviewboom in forum METALWORK GENERALReplies: 4Last Post: 29th Jul 2017, 03:24 PM -
rubber mallet
By sossity in forum METALWORK GENERALReplies: 2Last Post: 12th Dec 2016, 05:03 PM -
Rubber Linisher Wheel
By GZBMW in forum METALWORK GENERALReplies: 10Last Post: 18th Nov 2012, 08:02 PM -
Working with Rubber
By 19brendan81 in forum METALWORK GENERALReplies: 8Last Post: 26th Mar 2010, 10:58 AM
