Results 1 to 10 of 10
Thread: Premo mk 1
5th Feb 2019, 11:35 PM #1Novice
- Mar 2016
- Sutherland Shire, Sydney
- 24
Premo mk 1
Hi everyone, I couldn’t see too much on here about these but I have just picked up a Pemo Mk 1 that looks to me to be in good condition for its age, come with 5 chucks, a stack of drill bits and end mills, (I think) most of the milling slide, a turret attachment (but no tools?) and (I think) all of the change gears but I dont have the detail or a chart to check it. I have lots to learn about this piece of our industrial history and I doubt I will ever get to a std where my “skills” will test its shortcomings but there’s hoping...
Ill work out how to post some pix as the cleanup progresses as it is pretty grubby - WD40 and plenty of rags I think! It runs fine but needs a new flat belt. Is a link belt my best option for this?
Id love to get a copy of the manual please if anyone has one and also to confirm if I have all the change gears, all and any help appeciated! Cheers Leigh
6th Feb 2019, 12:34 AM #2
Hi Leigh
I've got a Premo. It has its good and bad points.
The headstock alignment is a nightmare . The silly motor countershaft arrangment is crude , it vibrates horribly at the higher speeds . With a better motor drive system the Premo will perform well.
6th Feb 2019, 12:49 AM #3Most Valued Member
Hi Leigh, found this on the Lathes UK website and have posted a link to it.
Hopefully it'll give you some information; Premo and Veem lathes
A manual is available also;
https://store.lathes.co.uk/print/MP687
6th Feb 2019, 10:35 PM #4Novice
- Mar 2016
- 24
Hi Morrisman, one of the photos Kryn posted shows a piece of chain hanging around the countershaft frame, I’m guessing that is hanging there to soak up some of that vibration - does that sound right?
7th Feb 2019, 06:50 PM #5
I will take a few pics of mine . This example here has V belts not flat belts. Maybe Its a mk2.The counter pulley on mine is a large diameter alloy two stepped pulley , I tried static balancing it but that had little effect. Its a good lathe I like it but it needs some tweaking .The counter shaft sits in a hinged casting that is mounted on the drip tray it pivots . its ok running the chuck at lower speeds but its horrible above 600 rpm. Spindle has TRB in it . One thing ,the half nut engagement is very poor it has no positive feel , the leadscrew pitch is rather fine for some reason .Be cautious when engaging the half nut... mine broke so I don't use the lathe for threading jobs.
7th Feb 2019, 08:07 PM #6Novice
- Mar 2016
- 24
Thanks Morrisman, some pix would be much appreciated
7th Feb 2019, 09:17 PM #7
The leadscrew measures at .0625 " pitch or 1/16". That's why the half nut engagement is tricky . Will upload pics tomorrow.
8th Feb 2019, 09:10 AM #8Most Valued Member
- Australia east coast
- 2,713
That's odd - are you sure it was original? Mine was 7/8" 8 TPI LH. I know this because I made a new leadscrew and half nuts for it.
Mine was a Premo Mk 1 flat belt lathe, no QCGB, no power feeds other than leadscrew. It wasn't a good lathe but was pretty well beaten up by the time I got it so no real reflection on its original condition/function. I made V belt sheaves for it, made new back gears etc, new spindle, bearings, re-bored the headstock casting, line bored the tailstock. It still wasn't great though a lot better. I sold it to a friend of mine when I got a Chipmaster and then a Maximat 11.
They are more robust and a bit more swing than a Hercus but that's not saying a lot.
PDW
8th Feb 2019, 10:36 AM #9
My mistake yep it is 8 tpi ....
8th Feb 2019, 11:46 AM #10
pics
Premo Mk3 lathe lubrication
By craigmarshall in forum METALWORK GENERALReplies: 26Last Post: 26th Jun 2020, 02:15 AM -
Premo Lathe
By Garry Edwards in forum METALWORK GENERALReplies: 23Last Post: 26th Jun 2020, 01:49 AM -
Change gears for Premo lathe
By Ruddy in forum METALWORK - Machinery, Equipment, MARKETReplies: 1Last Post: 1st Apr 2017, 10:03 PM -
Premo lathe
By morrisman in forum METALWORK GENERALReplies: 4Last Post: 20th Nov 2011, 08:21 AM
