Page 1 of 2 12 LastLast
Results 1 to 15 of 23
    Feb 2009
    moonbi nsw Aus
    69
    364
    Default Plasma Cutting Machines
    Some time back there was a flurry of blokes buying "Cut 40" and "Cut 50" Plasma Cutters for around $250 mark. I have a job coming up where I need to cut 12 plate MS into some part shapes. I was just wondering if I could have some feed back from those who bought these Chinese machines a while back, with a view to maybe me buying one from Ebay
    Just do it!
    Kind regards Rod
    Jun 2005
    Townsville, Tropical Nth Qld.
    226
    Rod, I have a Cut50, branded Okai, or similar, found out they are the primary maker in China. It has worked like a dream, only problem is that it won't work when my solar panels are generating as the DC/AC conversion upsets it's electronics so I just click the AC switch off in the meter box to use it.
    Rgds,
    Crocy.
    near Rockhampton
    6,217
    My cut40 is still working fine, however times have changed.
    These days pilot arc is far more common, although you will pay extra for the pilot arc. That is why you might see photo's of what appear to be identical machines with one priced far far cheaper then the other. The cheaper one will not have pilot arc, usually anyway.
    Feb 2009
    moonbi nsw Aus
    69
    364
    Thanks Crocy and RC. I remembered at the time there was quite a movement of fellas who bought them but I didn't remember seeing any feedback.
    The job that I have to do is not very big so I am weighing up whether or not I should lash out and buy on.
    I did notice some machines are saying that they will start readily on contact with the torch on the plate to be cut. Does that sound like a good feature as apposed to the pilot arc?
    Just do it!
    Kind regards Rod
    Feb 2013
    Laidley, SE Qld
    1,039
    My el cheapo Cut 40 does a very messy cut at 12mm. I recall a post 2 or 3 years ago where a few chimed in with their Cut 40 experiences and it seems they are not all equal, some do a respectable cut in 12mm, others struggle.
    There are certainly no more $200 Cut 40s on ebay, $350 or so seems to be the starting point.
    May 2011
    Murray Bridge S Aust.
    5,959
    Hi Rod, you might find it cheaper and less of a headache if you got them cut by someone in town, I believe there are several laser/plasma cutters in town.
    Feb 2009
    moonbi nsw Aus
    69
    364
    Thank you gentle men for your wise words. I started looking at combination machines that had Tig as well as Plasma Cut (it doesn't cost anything to look)
    I also looked at those toilet roll air dryer/filters. I bought a couple for the place I was working probably 30 years ago and they were only about $30, the price now is $150. I am soooo behind current products
    Just do it!
    Kind regards Rod
    near Rockhampton
    6,217
    Quote Originally Posted by bob ward View Post
    The Cut50 seems to be the cheaper mass produced one these days. around $250 with free postage. No pilot arc though. Add $50-$100 for a cut50 with pilot arc.
    Jun 2010
    Canberra
    1,322
    I think I was one of the cheap Cut-40 brigade. As I've posted before, my unit is good for up to 8mm, after that things get very ugly, and 12mm is a no-go.
    That said, for the right application, it's an excellent tool to have on hand.
    Also, now I'm familiar with it, I'm much better informed if I decide to get a more capable machine.
    Jun 2011
    Australia east coast
    2,713
    My Cut50 was $600 over 10 years ago. It's cut a hell of a lot of plate but 12mm really is its limit. It won't really do 12mm in 316, I know from sad experience.
    I solved that problem by buying a Cut120 but it's 3 phase. Funnily enough it cost me $600.....
    PDW
    Aug 2011
    Perth, Western Australia
    67
    362
    Picked up my no-name brand Cut 60 about 8 years ago. ($550 I think)
    It will do 12mm but its getting ugly and at full amps the duty cycle is useless. If its plain steel plate, cutting with the oxy/acy gives a cleaner cut.
    Dialed back a bit and it will cut 10mm anything all day with a good finish. Must be one of those suspect units.
    Tony
    Jun 2010
    Canberra
    1,322
    Clearly not all plasma cutters are created equal - UniMig's 45 amp machine says it'll cut 16mm and sever 20mm, while the Hypertherm Powermax 45 XP claims it'll cut 22mm, and sever 29mm.
    May 2006
    Canley Heights, NSW
    67
    529
    Quote Originally Posted by RustyArc View Post
    I have one of those Multi Purpose machines Plasma, Tig and Stick , the plasma cutter is rated at 40 amp and will do 10mm nicely and 12mm but a bit rough.
    Shane
    Got the square peg in the round hole, now can't get it out !!
    Jun 2011
    2,713
    This is true, the Thermal Dynamics and Hypertherm units are far superior to the Chinese ones. I used to have one in my Govt workshop.
    Unfortunately they're also 3X the price or more, maybe 5X.
    For the price you pay the circa $600 Chinese units do a quite acceptable job. I chew through tips but they're cheap enough bought in bulk that I don't care.
    As for oxy-fuel yeah I still have a couple of cutting rigs but the bottle rental was a killer there. Now I can buy an oxy bottle but I don't think I can buy acetylene yet in Tasmania. I am set up to do oxy-LPG if I need to but the 120A plasma cutter should cover it up to 35mm-40mm plate.
    PDW
  15. #15
    Dec 2018
    NSW
    586
    Quote Originally Posted by chambezio View Post
    Clean, dry air for any plasma is a must, consumable alloy plays a part too (IIRC they use some fancy alloy, so Chinesium metals will let you down). You might get the job done for 300 clams, but really depends on how critical your work is.
    The plasma arc and swirl characteristics of it tends to put a slight kerf and bevel on the job- particularly at the upper limit of the machine's amperage, so factor in cleanup for any critical dimensions.
    @chambezio, given your location, I'd be making contact with a few of the locals-
    Tim at Northwest sheet metal Gunnedah has CNC plasma, and does some great work up to 50mm last I heard. He's on facebook too.
    Mal @ Engineering unlimited runs a profile cutter.
    There are a few laser cutters up in Inverell who do contract work, but your qty may fall short.
    I think the guys at Southern steel also outsource some cutting work, not sure if they cut to plan if you supply a drawing, but might be worth asking (or you other favourite steel supplier).
  1. Plasma cutting machines....Help Please
    By riverbuilder in forum METALWORK GENERAL
    Last Post: 17th Oct 2015, 05:26 PM
  2. Plasma cutting capacity or waterjet cutting connections?
    Last Post: 4th Apr 2014, 11:06 AM
  3. CNC plasma cutting
    By Andy Mac in forum METALWORK GENERAL
    Last Post: 23rd May 2008, 12:01 AM
