Results 1 to 8 of 8
Thread: Removing blind rolled pin
14th Jan 2019, 12:09 AM #1Most Valued Member
- 5,942
What's the best way to remove a blind rolled pin.
I have a handle from a mates electric wheel chair, only does half a turn and has been sheared off. Thread size is 1/4"UNC and the rolled pin would be about 2.5mm
The handle is threaded internally, then to hold the threaded piece in place, they've installed a rolled pin, not all the way through, but about half way.
Hopefully the pics will explain it better.
Thanks in advance.
14th Jan 2019, 12:46 AM #2China
- Dec 2005
- South Australia
- 1,656
A old tap of the appropriate size screwed in, then gently work the pin out with vice grips taping with soft face hammer, i did this on camera tripod for a mate a couple of years ago handle was plastic so could use any heat easy out might work as well
14th Jan 2019, 06:57 AM #3Philomath in training
- 6,540
I'd look at replacing it with a grubscrew or similar when it is out too.
14th Jan 2019, 10:47 AM #4Intermediate Member
- Feb 2012
- 48
Just a thought if China's good suggestions are unsuccessfully implemented:
Drill through the handle via the roll pin using the biggest drill possible i.e. so the roll pin is acting as a drill guide. Then reversing the set-up, drill a bigger hole back down to the roll pin, the drill size only being enough to allow an appropriately sized pin punch to engage the roll pin's inner diameter, so as to then drive it out.
This will leave an extra hole, but one which would allow removal of the roll pin if required.
One of those designs that tells you it is either planned obsolescence or inadequate engineering.
Michael's suggestion is also good in this situation, since the threaded bolt/stud? appears insubstantial for something that appears to be used regularly
QuentinLast edited by Cueball; 14th Jan 2019 at 11:00 AM. Reason: Incorrect reference
15th Jan 2019, 12:04 AM #5Most Valued Member
- 5,942
Thanks Quentin, that's probably the only way to get it out, as I don't have an ezyout or a tap small enough to use Chinas suggestion.
Will use that idea, if I come across another Engineering FUBAR. Thanks China.
So no doubt, there will be more accidents like this.
This mate suffered a stroke at the age of 32, blind in one eye, partially blind in the other, only just has use of his right arm/hand, has a real bad speech impediment, and can't use his legs, plus has very poor control over the joystick. The controller is set too fine, but they won't change it????
Unfortunately the "engineers" that design some of this equipment, I don't think have any real idea as to the design faults they create.
Thanks again everyone.
15th Jan 2019, 05:12 AM #6Senior Member
- Aug 2007
- 292
If you have a side hammer you can try screwing a good sheet metal screw into the roll pin, hook on to the screw and pull the pin out.
One other remote possibility is to fill the roll pin with grease. Put a pin punch in the roll pin and hit it with a hammer. It might hydraulic the pin out. More likely squirt grease back out the slot into your face. I said it was a remote possibility.
Pete
15th Jan 2019, 05:08 PM #7Most Valued Member
- Healesville
- 2,129
It is highly likely that they wont change the settings coz they don't know how.
I think to adjust the joystick controller you need a PP1 programmer, or at least someone that has one, so it might be worth ringing around the wheelchair repairers.
Or second option could be a new joystick controller with the buttons that allow you to slow it down for indoor use and then speed it up for the drag strip.
You will need to know if it is a brushed or brushless controller and have a look on aliexpress.
cheers, shed
15th Jan 2019, 09:24 PM #8Most Valued Member
- 5,942
Thanks Shed, biggest problem is that he gets a new chair every 2 years, and NO ONE is supposed to deal with it, so I'm loath to modify the electrics.
When he has a problem with it, he has to ring DomCare and they then organise someone to deal with it. Biggest problem is that in usual circumstances the wheels turn very slowly.
On a Saturday recently, his new chair that he had for about 3 weeks, both castor wheels had lost their nuts, him beng partially blind didn't notice them missing until both bolts had worked thier way out, leaving him stuck in the middle of his lounge room, unable to go anywhere!!!!!
Fortunately I managed to find a couple of nuts to fit the bolts, when he reported what had happened, he was told that I was having him on, but I noticed 2 new nyloc nuts were fitted to it????
I've had to tow him out of a small sand bog on the side of the footpath, as the castors holding the wheels were bent, and it wouldnt go straight, the arm rests have had to be repaired, the bolts that hold the arm that holds the control box and joy stick have been stripped out of the aluminium block, this was fixed by fitting a couple of helicoils, the list goes on and on.
flattening hot rolled plate
By eskimo in forum METALWORK GENERALReplies: 18Last Post: 5th Aug 2018, 09:23 AM -
Cutting an internal blind keyway on lathe
By .RC. in forum METALWORK PROJECTSReplies: 6Last Post: 25th Sep 2016, 01:14 PM -
Removing bearings from blind holes
By jhovel in forum METALWORK GENERALReplies: 6Last Post: 4th Apr 2016, 01:18 PM -
Blind Hole Spotters
By colbra in forum METALWORK GENERALReplies: 8Last Post: 25th Aug 2012, 08:21 PM -
another rolled over tipper
By specialist in forum TRAILERS & OTHER FABRICATED STUFFReplies: 16Last Post: 13th Apr 2011, 10:50 PM
