Results 1 to 15 of 53
12th Jan 2019, 10:54 PM #1Diamond Member
- Sep 2006
- Australind , WA
- 58
- 1,281
DIY Water proof Vapour Blasting Cabinet
Hi Gents,
I have just discovered that it may be relatively easy to make a 'working' DIY Vapour Blasting setup, but I am still trying to find the perfect place to start, ie water proof Cabinet.
I already have a Clemco steel cabinet, but I don't think it would be suitable to use water in it as it will rust quite quickly. I will sell that once this is working.
The Hare and Forbes cabinet are all steel as well, abeit painted on so will fair a bit better.
I have seen the large plastic drums used but they are a bit problematic as well. ( it's difficut to add a window to a round object )
I really want a square sided water proof cabinet. It looks like I may have to faricate one from scratch, but that has hurdles as well....
What material to use? Plastic sheet with a metal frame? Plastic sheet would be expensive and a bit of work to cut to size. I'd then have to seal the edges.....
Don't think a plywood sided cabinet would last long in a wet enviroment, even if I did seal the inside.
Ive seen a dishwasher carcass used ...... possible but I thought maybe a little small? ( need room for a wiper on the inside of the window. )
Thought about large plastic storage tubs from Bunnings, but they seem a bit small as well.
Aluminium enclosure bent up and welded?....very spendy!
Anybody have any other I deas I may have overlooked?
12th Jan 2019, 11:39 PM #2Member: Blue and white apron brigade
Not really - provided its a cylinder or conical and and not egg shaped.
I use 1mm thick Polycarbonate (PC) because it's very flexible and strong.
[QUOTEI really want a square sided water proof cabinet. It looks like I may have to faricate one from scratch, but that has hurdles as well....
What material to use? Plastic sheet with a metal frame? Plastic sheet would be expensive and a bit of work to cut to size. I'd then have to seal the edges.....[/QUOTE]
Most things plastic are more expensive than you think.
Large HDPE aquarium ponds would work but be prepared to sit down before you check prices.
I've made a few fume hoods using the following.
3 or 4 mm Plastic sheet (poly propylene or HDPE pr PVC), cut with WW table saw, heat and bend the sides and edges, fold into box shape, nylon or SS bolt edges to sides, leave front open and cover with acrylic or PC sheet.
Ideally you'd need a proper plastic heater/bender to bend long sides and edges.
Silicone all edges.
Too complicated? painted steel frame, plastic sheet ss screwed to steel, edges sealed with Silicone, will be more fiddly but will work.
If you did that I would use clear 1mm PC sheet all round - you can get rolls of this at Bunnings.
Alternative solution.
Ply box and use a plastic pond liner and PC or acrylic front.
You might even be able to get away with thick HDPE builders film and seal edges with Silicone.
13th Jan 2019, 12:07 AM #3Golden Member
- Mar 2009
- 54
- 825
1000lt shuttles are redily available and fairly cheap, might be a bit on the large side though.
Greg.
13th Jan 2019, 12:35 AM #4
So you have a suitable compressor yet? These things need a very large amount of compressed air.
I think I saw the same source as you did. https://www.youtube.com/watch?v=mUfgjK5q_Mc. I thought it was pretty interesting too.Cheers, Joe
13th Jan 2019, 10:27 AM #5Member: Blue and white apron brigade
Interesting vid Joe, thanks for the link.
So its not really "vapour" blasting , it's plain water/abrasive blasting.
The guy in the vid is flogging a US$69 vid.
As one of the comments under the vid suggests once the type of pump used is determined most mechanically minded persons should be able to work out how to do the rest.
The pump needs to stir up the water and abrasive as well as deliver enough water to the height of the height of the spray gun. It doesn't need a lot of pressure as this is provided by the compressed air.
The suggestions are a 1/4HP submersible is all that is required. For extended use an abrasive resistant pump would be handy but otherwise for occasional use a plastic pump might even be OK?
13th Jan 2019, 10:43 AM #6Diamond Member
- Aug 2006
- 1,106
So it is sort of a similar process to the pressure washer blasting setups, except you don't need a compressor or cabinet?
https://www.ebay.com.au/itm/Industri...b8:rk:108:pf:0
I saw that youtube video, I can't seem to see $1300 worth of parts in there (that's probably US $$$ as well) unless it is a very expensive pump.
13th Jan 2019, 12:16 PM #7Member: Blue and white apron brigade
Sure provided you don't want to recover your abrasive and don't care if you get wet.
If you can recover your abrasive you can use better quality stuff like glass beads which gives a really nice finish.
13th Jan 2019, 01:37 PM #8Diamond Member
- Sep 2006
- Australind , WA
- 58
- 1,281
13th Jan 2019, 01:41 PM #9Diamond Member
- Sep 2006
- Australind , WA
- 58
- 1,281
I thought of those. I can get as many as I want form work, but I think 1000L tanks would be too big.
Here's a pic of the Clemco cabinet.
13th Jan 2019, 01:43 PM #10Diamond Member
- Sep 2006
- Australind , WA
- 58
- 1,281
13th Jan 2019, 01:46 PM #11Diamond Member
- Sep 2006
- Australind , WA
- 58
- 1,281
13th Jan 2019, 02:56 PM #12Philomath in training
- 6,562
What about a plastic tub?
https://www.richmondau.com/product-c...angular-tanks/
13th Jan 2019, 03:29 PM #13Most Valued Member
What about using an old fridge/freezer, on its side. The insides are one piece, the door could be used for large pieces, and you'd probably pick one up off the side of the road on Council Clean Up days.
13th Jan 2019, 03:39 PM #14Member: Blue and white apron brigade
13th Jan 2019, 09:51 PM #15Diamond Member
- Sep 2006
- Australind , WA
- 58
- 1,281
Grit Blasting Cabinet.
By BaronJ in forum METALWORK GENERALReplies: 21Last Post: 7th Dec 2015, 09:43 AM -
Heat proof glue
By Ueee in forum METALWORK GENERALReplies: 15Last Post: 15th Aug 2014, 03:44 PM -
Who's got a Sand Blasting Cabinet?
By Sterob in forum METALWORK GENERALReplies: 59Last Post: 24th Nov 2010, 09:33 PM -
Coolant/Oil proof paint?
By John H in forum METALWORK GENERALReplies: 6Last Post: 26th Sep 2009, 10:11 PM -
Vandal / Kick proof fence
By benny353 in forum METALWORK GENERALReplies: 16Last Post: 17th Aug 2009, 11:00 PM
