Page 4 of 4 FirstFirst 1234
Results 46 to 53 of 53
  1. #46
    Sep 2006
    Australind , WA
    58
    1,281
    Interesting Post Joe.
    Your not put off then?....
    Whats the flow rate of your slurry pump?
    Are you agitating your glass beads at all?
    I've seen those guns and I think they consume a serious amount of air.
    We might need a smaller version. The guy in NZ , on U Tube has been experimenting with a smaller DIY gun.
    Good luch with your experiementing.
  2. #47
    Aug 2010
    Near Bendigo, Victoria, AUS
    72
    3,104
    No, not put off yet...
    I don't have numbers for the flow rate. A good amount, but not much pressure.
    If you look on the photo inside the drum, you can just make out the shiny stirring nozzle, and the third photo (large version) shows the valves for mixing and pumping out. it stirs quite well; The outlet to the pump is in the middle under the paddles.
    The air jet is about 1.6mm bore.
    A smaller version would make it even slower in terms of impact area I think.
    I'd rather pursue a bigger pump and a bigger compressor....
    Off for a rest at the beach for a week now. Will update as I get to it again.
    Cheers, Joe
  3. #48
    Jul 2012
    Malvern East
    84
    Just so you know the way to get the lustre up is turn the air off
    Use the water slurry to polish the part. the air is the speed factor and the lustre is the pumped slurry
    (Dana Ridge unit at work and have spoken to the agent directly about it it gets those CT cases good and shiny same as mass finishing)
    Regards Bruce
  4. #49
    Aug 2010
    72
    3,104
    Thanks Bruce,
    what size water pump does the Dana Ridge use and what pressure does it produce? Also, roughly what diameter is the slurry nozzle on it?
    Last question: what size medium do you use in the Dana on aluminium?
    I'm back from my little camping break, and I want to experiment a bit more.
    I have a Honda powered single impeller fire fighting pump (5HP) which is spare. I'm thinking I might try with that... Any thoughts?
    Cheers, Joe
  5. #50
    Jul 2012
    Malvern East
    84
    Get back to you tomorrow Joe
  6. #51
    Jul 2012
    Malvern East
    84
    Right
    Pump pipework all two inch dia
    Flow 20 litres per 15 seconds ( Bucket and stop watch)
    Nozzle dia 5 mm (carbide)
    Interesting side note as slurry was allowed to settle not more than 10-12mm deep coating in base of bucket
    INDA Grade glass bead
    Sorry been really busy at work at could not get near it for a couple of days
    Bruce
  7. #52
    Aug 2010
    72
    3,104
    Very useful information. Thank you. That's a flow rate of 80l/min! No wonder my pump is a bit wimpy. When I get a chance, I'll hook up the fire pump and see what flow rate I can get. I'll ale have to get some glass bead medium. I've been using the stuff from my dry blasting cabinet. Garnet I think, I don;t think that will do the pump any good in the longer run...
    Cheers, Joe
  8. #53
    Sep 2006
    Australind , WA
    58
    1,281
    I've read that 40 -50L/s flow rates work ok......no evidence to prove.....
    That is what I was going to work on.
  1. Grit Blasting Cabinet.
    By BaronJ in forum METALWORK GENERAL
    Last Post: 7th Dec 2015, 09:43 AM
  2. Heat proof glue
    By Ueee in forum METALWORK GENERAL
    Last Post: 15th Aug 2014, 03:44 PM
  3. Who's got a Sand Blasting Cabinet?
    By Sterob in forum METALWORK GENERAL
    Last Post: 24th Nov 2010, 09:33 PM
  4. Coolant/Oil proof paint?
    By John H in forum METALWORK GENERAL
    Last Post: 26th Sep 2009, 10:11 PM
  5. Vandal / Kick proof fence
    By benny353 in forum METALWORK GENERAL
    Last Post: 17th Aug 2009, 11:00 PM
