Results 1 to 8 of 8
Thread: Hafco HM10 mill drill
7th Jan 2019, 04:17 PM #1Intermediate Member
- Dec 2018
- Perth, West Australia
- 63
- 28
I have had the HM10 for a few years, but found the 350W motor not quite powerful enough to do what i need, and it will "stall" sometimes.
I recently acquired a herless SM1 Vertical mill, in good nick, but it is probably too big for what i need and my limited skill set.
Is there an uprated electric motor available for the HM10? That would probably solve my issues if it was an easy install and i can sell the SM1...
7th Jan 2019, 05:23 PM #2Most Valued Member
- Jul 2016
- 35
- 1,522
SM1 is still a pretty small mill if its the one with the tilting top ram? I dont really think mill size has anything to do with skill really, youll make the same mistakes big or small and the consequences arent much worse on a machine 30% bigger.
7th Jan 2019, 07:10 PM #3Senior Member
- Feb 2012
- Willunga
- 114
I am just installing a machine like the SM1 after having a round column mill - it is so much better. It is much more rigid and creates a lot less vibration. My opinion for what its worth is stick with the SM1.
8th Jan 2019, 08:40 AM #4Senior Member
- Oct 2009
- Upwey VIC
- 186
X2 (same mill) motor and drive upgrade in this link:
//metalworkforums.com/f65/t1983...l-mods-upgrade
Andrew
8th Jan 2019, 11:32 AM #5Intermediate Member
- Dec 2018
- 63
- 28
Thanks Andrew,
I think that may be a little over the top for what I want, I was just thinking of a 500w motor instead of the 350w standard one. The Seig SX2 mill is essentially the same but with 500w DC moter, wondering if it is a easy exchange as they have different mounting points
8th Jan 2019, 12:52 PM #6Member: Blue and white apron brigade
- 7,182
if the motors have different mounting points you might as well add an adapter plate and use a 1HP 3P motor on it and drive it with a VFD.
Happy to help with the VFD side of things seeing as you are local.
8th Jan 2019, 01:09 PM #7Intermediate Member
- Dec 2018
- 63
- 28
Hi Bob,
Thanks, but I dont have 3 phase, and, excuse my beginers ignorance, what is VFD short for?
8th Jan 2019, 01:26 PM #8Member: Blue and white apron brigade
- 7,182
Hi Jonny, you don't need 3Phase power. The VFD runs from 240 and makes the 3Phase using the VFD (Variable frequency drive).
Check this out.
VFD install summaries
Another Problem with my Hafco HM-46 Mill Drill
By Jarh73 in forum METALWORK GENERALReplies: 29Last Post: 23rd Oct 2018, 01:29 AM -
HAFCO HM-45 CNC Mill Conversion
By velocis in forum METALWORK GENERALReplies: 6Last Post: 26th Aug 2013, 09:47 AM -
SOLD: Hafco Mill (X3 Sieg)
By dmgrai in forum METALWORK - Machinery, Equipment, MARKETReplies: 3Last Post: 30th Jul 2013, 02:14 PM -
Problem With a Hafco HM-46 Mill/Drill.
By Jarh73 in forum METALWORK GENERALReplies: 28Last Post: 23rd Jul 2012, 11:51 AM -
HM10 or X2 Mill
By Big Shed in forum METALWORK GENERALReplies: 3Last Post: 26th Aug 2008, 05:24 PM
