Results 1 to 9 of 9
    Dec 2005
    South Australia
    1,657
    Default Is small bandsaw able to cut heavy steel
    I have a small bandsaw same as H&F BS-4 I wish to cut a shape on each end of a piece of 150 mm x 25 mm mild steel to fit into the web side of a 100 x 100 RSJ , those who this type of machine would I be pushing it uphill
    7,188
    It will do it slowly and you won't be damaging the machine.
    Dec 2005
    South Australia
    1,657
    Thanks for that, I do intend to take it slowly.
    Oct 2011
    Norwood-ish, Adelaide
    59
    6,559
    I cut a piece of 160mm diameter round on mine the other day. Took a while but no problems doing it.
    Aug 2010
    Near Bendigo, Victoria, AUS
    72
    3,105
    If you look back at bandsaw topics here, you will learn a lot.
    The limiting factor is the saw opening - and can be overcome by turning the work over. The other limit is the space in the blade gulltes to move chips out of the work. So for large sections, use LESS teeth per inch to make bigger gullets. I use a 4.5 tooth per inc blade when I cut large solid sections and the little saw cuts them like butter. Smaller teeth makes the chips 'roll' under the blade - a bit like ball bearings - and lift it off the work, so slowing down the cutting to snail's pace but heating up the blade, making it blunt.
    Cheers, Joe
    Dec 2005
    South Australia
    1,657
    Thanks for the replies all positive info, Just o make things clear this will be cut using it in thee upright position on the table
    May 2011
    Murray Bridge S Aust.
    5,959
    I cut some tractor weights that were about 300 square and approx 30 mm thick on my 6X4 saw on the vertical, with no problem. Joe will know the weights I'm talking about, as I got them from him. Just a matter of using the right blade, I think I used something like a 12TPI blade.
    Nov 2012
    Blue Mtns
    115
    I don’t know that model but I have an old English made bandsaw that wasn’t overly solid. I cut some 2” black plate by use 3 claw blade and taking it easy
    Aug 2015
    Melbourne, Australia
    843
    I keep a 4 (or 5?) tooth-per-inch bi-metal blade handy for the bigger stuff. As Joe says - cuts like butter.
    Get a low tpi blade and go for it.
  1. Steel plate orientation when cutting on a bandsaw.
    By Jim Ferrous in forum METALWORK GENERAL
    Last Post: 8th Nov 2013, 08:29 AM
  2. Carbon Steel Bandsaw Blades
    By Auskart in forum METALWORK GENERAL
    Last Post: 27th Feb 2013, 07:09 AM
  3. Bandsaw suitable for steel?
    By mike rolly in forum METALWORK GENERAL
    Last Post: 24th Aug 2011, 08:59 PM
  4. Replies: 24
    Last Post: 14th Dec 2010, 07:37 PM
  5. welding very thick heavy duty steel??
    By Mathuranatha in forum WELDING
    Last Post: 21st Jun 2008, 09:28 AM
