Results 1 to 5 of 5
Thread: heating
5th Jan 2019, 07:40 PM #1Senior Member
- Apr 2014
- 134
heating
hi
will a propane gas bottle with a heating torch give enough heat to bend
a 50x8 mm bar at right angles
cheers steve
5th Jan 2019, 10:57 PM #2Senior Member
- Oct 2015
- melbourne
- 473
Maybe, if you can arrange some firebrick to minimise the heat loss.
Depends on how tight the bend radius is.
And how long the piece is, to get leverage.
Russ
6th Jan 2019, 02:13 AM #3China
- Dec 2005
- South Australia
- 1,658
Also will depend on the burner size
6th Jan 2019, 10:29 AM #4Most Valued Member
- 4,258
charcoal will do it..it will take a while to get it red hot and a fan assisted charcoal bed will be hotter
6th Jan 2019, 06:29 PM #5Golden Member
- Aug 2015
- Melbourne, Australia
- 843
If it is the bunnings type then they struggle to make anything truly hot - maybe hot enough for helping press stuff in out of other parts etc but *really* hot - nope.
I keep a few red bricks dry and out of the weather so that if I need to heat something as best I can I arrange them and the piece such that the heat doesn't escape too much.
Greg.
Oxy/LPG. Heating Tip
By DSEL74 in forum WELDINGReplies: 8Last Post: 20th Feb 2018, 09:31 PM -
Heating Oil - moved from Foundry
By Turbine Builder in forum METALWORK - Machinery, Equipment, MARKETReplies: 4Last Post: 28th Jan 2018, 09:54 PM -
Oxy heating tip vs welding tip
By Matt_M in forum METALWORK GENERALReplies: 5Last Post: 11th Jan 2015, 06:31 PM -
LPG heating torches
By shedhappens in forum METALWORK GENERALReplies: 67Last Post: 31st Aug 2012, 10:36 PM -
Heating jig
By Tiger in forum METALWORK GENERALReplies: 10Last Post: 2nd Mar 2006, 08:16 PM
