Results 1 to 5 of 5
Thread: Douglas Shaper Vice Improvements
23rd Dec 2018, 08:34 PM #1.
- 6,459
I have been using my Douglas shaper more frequently of late mainly due to the neat finish it imparts. Neat finish is one thing, accuracy's another and it was lacking. The shaper would cut a taper on anything held in its vice, about a thou in two inches. So with accuracy being more important than cosmetics I did something about it.
The table top face was not square to the x axis so I recut its surface.
The vice base when checked with an indicator, had three roughly equally spaced high points. Clamped at those points onto a faceplate, I cleaned up the bottom face of the base with a HSS cutter. Then I used the boring head in its facing mode to clean up the upper surface.
IMG_20181218_150228056 (Large).jpg IMG_20181218_151507697 (Large).jpg IMG_20181218_154121732 (Large).jpg IMG_20181219_120614796 (Large).jpg IMG_20181219_120915878 (Large).jpg IMG_20181219_153447866 (Large).jpg
With the base cleaned up I was able to "survey" the vice which revealed a drop of around 0.0035" in one corner and a slight hollow in the middle of its ways. There was considerable damage to the ways directly in front of the fixed jaw and to remove it I had to cut to a depth of around 0.010". In the process, I neglected to lock the downfeed on the shaper's head and it auto fed itself into the narrow section of the bed casting. I "fixed" the mess up on the mill.
IMG_20181222_124325439 (Large).jpg IMG_20181222_130130421 (Large).jpg IMG_20181222_130124317 (Large).jpg
The lowering of the ways resulted in some variation in the thickness of the way edge or lip. I used an endmill to carefully recut the underside of the lip.
IMG_20181222_152047205 (Large).jpg IMG_20181222_152841459 (Large).jpg IMG_20181222_155250553 (Large).jpg IMG_20181222_155319064 (Large).jpg IMG_20181222_163414230 (Large).jpg
The reduction in lip thickness also required modification to the sliding jaw. Before I could work on the sliding jaw the fixed jaw had to be cut down to the sliding jaw's height to enable the vice to be clamped upside down on the mill's table.
IMG_20181223_105609102 (Large).jpg IMG_20181223_110606549 (Large).jpg IMG_20181223_121229726 (Large).jpg IMG_20181223_123414297 (Large).jpg
With the modifications completed and the vice reassembled there is no discernible needle movement on a 0.01mm indicator when traversed along a 6" parallel resting on the vice ways.
Worth the effort.
Bob.
23rd Dec 2018, 08:42 PM #2Intermediate Member
- Sep 2016
- Morphett Vale SA
- 56
- 27
Hi Bob,fantastic work and thankyou for taking the time to document it.I probably need to do the same for my shaper but will wait until I've found a more correct vise.
Cheers Nick
23rd Dec 2018, 09:23 PM #3Most Valued Member
Thanks for posting Bob. Something I will do in the new year too.
23rd Dec 2018, 10:20 PM #4Golden Member
- Jul 2011
- 837
Bob
Did you consider fixing the variation in the thickness of the way edge with the shaper? Wondering why you chose the milling machine for this part. No way of getting the clapper box to work properly on a cut on the underside?
Eric
24th Dec 2018, 02:07 AM #5.
- 6,459
Eric,
To be honest I never contemplated using the shaper for dealing with the way edges. The mill seemed like the only option. Douglas appear to have used an endmill in a similar fashion.
My greatest challenge was holding the vice body level and parallel to the x axis. While the photos show a helix clamp restraining the vice's outboard end, the clamp when tightened twisted the vice body out of alignment. The clamp was replaced with a simple vice stop that worked well enough to prevent cutter induced deflection.
The shaper's absence of graduated collars on the table feeds making table movement pretty much guesswork, renders some operations difficult. The decision to use the mill was easy.
Bob.
Wanting to get a hold of a Douglas shaper vice!
By BrazOmatic in forum WANTED TO BUYReplies: 1Last Post: 20th Jul 2018, 08:04 PM -
Wanted to buy Douglas shaper vice.
By lamestllama in forum WANTED TO BUYReplies: 0Last Post: 10th Jan 2018, 06:29 PM -
WTB Douglas Shaper Vice
By lamestllama in forum WANTED TO BUYReplies: 0Last Post: 18th Jul 2017, 07:55 PM -
Douglas/Hercus shaper vice maybe.
By stix012 in forum EBAY, GUMTREE, and other off forum sales sitesReplies: 0Last Post: 17th Aug 2016, 09:23 PM -
SOLD: Douglas Shaper Vice
By 4-6-4 in forum METALWORK - Machinery, Equipment, MARKETReplies: 4Last Post: 30th Apr 2012, 12:11 AM
